10T to T2 Stealth question
Quartermilecrazy
Post by Quartermilecrazy »
I have a late model 10T with a 2.25 stealth. I think for the direction I am going a 2.6 would be a better option for me. Can I just change out the gears inside or do I have to buy a new trans? TIA
Enter witty comment here
Been thanked: 3919 times
Re: 10T to T2 Stealth question
Not compatible, the case is different and the diff of a T2 is the same as a GT. Rpm made a conversion box but it is discontinued.
Quartermilecrazy
gomachv wrote:Not compatible, the case is different and the diff of a T2 is the same as a GT. Rpm made a conversion box but it is discontinued.
That was quick. So unless I find an RPM case I am SOL? Will a T2 trans bolt to a 10T chassis? What trans ratio did the stealth buggies have?
Basically, I am asking, what are my options to getting a 2.6 in my truck?
You might be able to fab something but it's far from a drop in. Best bet is to find a cheap T2 donor for the chassis, bulkhead, rear tower and trans. Swap over all your suspension and nose. There was one for around $30 on eBay just a few days ago (I can't find it now tho). The rpm conversion was cheap when it was manufacturered but expensive now
Buggy stealth is same as truck stealth up to the T2
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarAhrefs [Bot] and 13 guests
