Stealth Question
General info, Q&A.
TViz
Stealth Question
Post by TViz »
Hey folks.
My stealth tranny came in the mail. Yippee. :D
It didn't come with any spur gear/spring/slipper etc... Basically, just the tranny, original felt and motor plate.
There's a few options out there that I've read about on these forums but not sure which to go with.
Can someone make a recommendation for me please, including links or part numbers so I can purchase the parts and start using the tranny. Thanks in advance.
aconsola
Re: Stealth Question
Post by aconsola »
If you are planning to use the trans in a runner, you could adapt the modern rc10b4 slipper to work
Parts list needed is in here:
http://www.rc10talk.com/viewtopic.php?f=38&t=10403
The b-3 slipper parts will work as a direct replacement for the original as there was only a minor change in the slipper pad and plates between the 2 versions.
you need one each of:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX3445&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX3446&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX3447&P=M
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2885&P=M
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2879&P=M
3/16x3/8" bearing
and 2 4-40x3/16" buton head screws.
Alternatively you could just bolt a spur gear to the top shaft with a slipper eliminator like this one:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNTP5&P=7
(the eliminator is popular for oval racing)
TViz
Post by TViz »
Thanks aconsola. Where in the "what's old is new" thread did you see the B4 setup? I looked and couldn't really find anything specific. Would I need to change the top shaft for the B4 set up?
I don't want to eliminate the slipper because I'm running brushless and don't want to risk damaging the internals.
Thanks again.
soniccj5
Post by soniccj5 »
The following part list was included with RichieRich build.
Transmission
9601 B4 topshaft
9603 B4 slipper pads
9651 Spur gear
9604 Slipper hub x 2
9605 Slipper spring
RPM gear cover cap
ED
TViz
Post by TViz »
Yep, did a little more searching. Found what I needed. Going to go with the B4 setup. Can't wait to get the parts in. Thanks for the help.
ChicagoRC10T
Post by ChicagoRC10T »
Has anyone successfully done the B4/T4 slipper on an RPM converted stealth? Looking briefly through the archives, it doesn't seem like it. I understand the RPM top shaft is shorter, but maybe a shorter spring could be used? Does anyone who has both shafts know the difference in length? Are there any other obstacles to doing this? I'm sure a significant amount of adjustment fidelity would be lost, but depending on the delta length, it might be worth it.
ChicagoRC10T wrote:Has anyone successfully done the B4/T4 slipper on an RPM converted stealth? Looking briefly through the archives, it doesn't seem like it. I understand the RPM top shaft is shorter, but maybe a shorter spring could be used? Does anyone who has both shafts know the difference in length? Are there any other obstacles to doing this? I'm sure a significant amount of adjustment fidelity would be lost, but depending on the delta length, it might be worth it.
the only way you could do it would be to press the gear off both the b4 and rpm top shaft, and re-install the gear for the rpm top shaft on to the b4 top shaft.
badhoopty
Has thanked: 183 times
Been thanked: 157 times
Post by badhoopty »
i was told awhile back (i forget who...) when i was putting together the stinky pinky that an rpm topshaft for a hyperdrive could possibly work with a b4 style slipper.
badhoopty wrote:i was told awhile back (i forget who...) when i was putting together the stinky pinky that an rpm topshaft for a hyperdrive could possibly work with a b4 style slipper.
i tried it, put the shaft doesn't seem to be long enough.
noony
Has thanked: 5 times
Been thanked: 29 times
Post by noony »
So there was a hyper-drive top shaft for the RPM trans?
noony wrote:So there was a hyper-drive top shaft for the RPM trans?
hydra-drive...... yes. you could get an rpm 2.65 conversion kit with the slipper shaft or the hydra shaft. you could buy them individually, too.
noony
Post by noony »
Thanks Jason :wink:
burnsmonkey
Post by burnsmonkey »
So what slipper are you running with your RPM trans?
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Post by adam lancia »
RPM did have a Hydra-Drive top shaft for their transmission but they're pretty hard to find now.
burnsmonkey wrote:So what slipper are you running with your RPM trans?
the one from the 2.25 stealth or the one from the 2.40.(b2, b3, t3).
Users browsing this forum: No registered users and 14 guests
