stain removal from nylon
GJW
Post by GJW »
here is one for ya's, i have a few different bits of white/cream nylon with similar stains, was going to try rit colour remover but thought i might ask on here.
seams to have soaked in below the surface of the nylon.
Re: stain removal from nylon
give it a try. It could also be contamination in the material. I had a set of wheels I just dyed that where white nylon that had a tiny little bit of purple colored spots, I assume from colored plastic that got stuck in the mix.
GJW
Post by GJW »
certainly looks to be in the nylon, ill let ya know how i go. got quite a few pieces with similar contamination :?
Jay Dub
Post by Jay Dub »
I have had various pieces molded with imperfections in the plastic. If this is the case, the only hope is replacement. -Jeff
GJW
Post by GJW »
Jay Dub wrote:I have had various pieces molded with imperfections in the plastic. If this is the case, the only hope is replacement. -Jeff
might just dye it black, and get a fresh white one. thanks dude 8)
mopar marv
Post by mopar marv »
A friend from another website, uses peroxide[hair bleach] to clean his parts. He soaks them in a big Rubbermaid tub sitting in the sun for a couple of days. And so far it seems to work very well. All of his vintage RCs that I have seen look brand spankin' new.
The Manic Mechanic
the other option you have it to lightly scrape the stained part. If the blemish isn't very deep, you can scratch it away and blend it in, and unless you are looking at it more closely than a normal person should, you won't see it.
I use a nice fresh exacto to scrape frayed edges and stained spots on arms and stuff.
GJW
Post by GJW »
mopar marv wrote:A friend from another website, uses peroxide[hair bleach] to clean his parts. He soaks them in a big Rubbermaid tub sitting in the sun for a couple of days. And so far it seems to work very well. All of his vintage RCs that I have seen look brand spankin' new.
yes marv we have been on too the peroxide trick for quite a while on rc10talk :wink no luck for my parts with this method :roll:
jwscab wrote:the other option you have it to lightly scrape the stained part. If the blemish isn't very deep, you can scratch it away and blend it in, and unless you are looking at it more closely than a normal person should, you won't see it.
looking to close! yep guilty, some parts i have done just that mate with the exacto, but other's i just cant :roll:
mopar marv
Cool !
I guess I'm a little behind everyone else,I just found out about the peroxide trick a couple of months ago. :oops:
The Manic Mechanic
Users browsing this forum: No User Avatar1911Colt and 6 guests
