I've heard of laser hair removal, laser rust removal?
- flipwils11
- Been thanked: 19 times
Reason: fixed youtube link
- Halgar
- Has thanked: 146 times
- Been thanked: 196 times
Re: I've heard of laser hair removal, laser rust removal?
What will they come up with next? I wonder how the laser fairs against the electrolysis process, as far as being non-destructive to delicate pieces. If you watch this video to the end and the screen pops up with related vids, the one in the bottom center is an Aussie that uses water and molasses, which removes the rust without disturbing the metal, which means that very delicate, thin metal details can be saved.
- Been thanked: 325 times
Very cool. That looks like a cast-iron grate or something, I wonder how that would work on sheetmetal? It looks good for removing surface rust, but the bottom line is, rust has already eaten into the metal and regardless of how it's removed, the metal may likely still have weakened. If you can push a screwdriver through a rusty sheetmetal panel, you might be able to remove the rust with laser, but you'll still be able to push a screwdriver through it.
- Diamond Dave
- Has thanked: 699 times
- Been thanked: 130 times
That is crazy! No gloves, no smoke, just nutz!
Like Halgar said, what is next? So cool...
- uniquenamehere
- Halgar
Nothing a little Bondo can't fix!Coelacanth wrote:If you can push a screwdriver through a rusty sheetmetal panel, you might be able to remove the rust with laser, but you'll still be able to push a screwdriver through it.
- 2416 Views
Last post by RedScampi
- 1658 Views
Last post by XLR8
- 1934 Views
Last post by winner_evo
- 3404 Views
Last post by OptimaZe
- 1799 Views
- 24 Replies
- 5970 Views
- 29 Replies
- 3338 Views
Last post by Erich Reichert
- 1571 Views
Last post by Eau Rouge
