Can nylon be painted
radioactivity
Has thanked: 384 times
Been thanked: 618 times
Post by radioactivity »
I can't find any good references on priming or painting nylon.
Has anyone had any luck or experience?
Tamiya had a special primer for polypropylene, nylon, FRP and other similar materials.
It seems to be discontinued.
Chuck
Been thanked: 3919 times
Re: Can nylon be painted
I can’t speak for painting as I personally would never paint nylon, but I can speak for Rit Dyemore if it’s something you could dye. It works great.
Zac_F71
Post by Zac_F71 »
It can be painted sure, good prep will help it stick, but if you run it on dirt/race it don't expect it to last. Like Jeff said dying it is the best solution
radioactivity
Thanks Zac_F71
Any tips? light sanding for mechanical bond ? Best primer?
I realize dyeing is a durable option. I've dyed many nylon parts for a long time.
I ordered JC racing wheels and may try to hydrodip them to match my paint.
Not for dirt or bashing. Shelf or possibly, possibly carpet.
Chuck
radioactivity
It took me a bit, but I've gotten some fairly satisfactory results.
The first "dip" did not go well, so i had to strip and start over.
Basically I sanded, used adhesion promoter, dipped the wheels and cleared coated them.
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
That looks great! Looks like they were carved from blue marble. Should look great mounted on the car with similar body paint.
radioactivity
Thank you xlr8!
I really appreciate your kind words.
I guess a dipped car isn't everyones cup-of-tea but I really like the look.
Unfortunately I may not have the painting skillset that others on the forum possess.
Chuck
XLR8
Post by XLR8 »
Well, I certainly don't possess great painting skills but it's obvious that you have this hydro painting technique sorted out. So, obvious question; when will we see the completed car with these wheels?
radioactivity
Ive been slowly collecting parts, polishing old metal parts, anodizing aluminum and titanium, dyeing or redyeing parts.
It seems like every time I make a "complete" order I want twice as many more parts.
Guess it will never be finished.
It is sunny today and that is what my camera likes.
After I cut the grass...
Chuck
fst72vette
Has thanked: 10 times
Post by fst72vette »
Lookin good! Your gettin good at this is see. What kind of wheels are they? Are they 2.2 12mm hex?
radioactivity
Thanks fst72vette
Sorry for the late reply
The wheels are jcracingproducts wheels.
At least a few others here on the forum have used them. They are very nice 2.2 wheels that are a direct fit for 1/4" tapered axel rears and the fronts work with 3/8 x 3/16 front bearings.
The wheels will come either yellow or white. It takes a couple of weeks to get them from England.
Chuck
