Adhesives that bond with nylon
Has thanked: 2605 times
Been thanked: 2979 times
Has anyone found any adhesives that seem to make a good bond with nylon? I sometimes have parts with holes I would like to have with a tighter fit without using oversized fasteners. I haven't tried JB Weld or Plastic Welder yet, but would like to hear some experiences before I start testing.
Has thanked: 269 times
Been thanked: 2094 times
Re: Adhesives that bond with nylon
If its a 4-40 hole, I'll step up to M3. After that, I'll use a Helicoil or brass insert.
For 8-32, I go directly to the coil or insert.
I've tried tapping holes filled with CA, it didn't want to hold.
Cyanoacrylate glue or crazy glue, is about the best for most nylon joints. It's not as flexible so it needs to be a secure connection. It works very well for repairs where something has snapped but not stretched. Rough surface is helpful also.
Tapping a hole filled with CA is not good because the act of forming the threads will tear it out.
For thread repair, I'll place a drop of CA in the hole, and a drop of oil on the threads of the screw, then fasten like normal. The oil on the threads prevents the glue from full attaching to the screw., Which allows you to remove at some point in the future.
As for trying to shim up hinge pin holes with some kind of glue, that tiny gap is very hard to fill with something that will stick. For that type of application, it's better to open up to 9/32" and use brass tubing with 1/8" Id.
LTO_Dave
Has thanked: 52 times
Been thanked: 287 times
Post by LTO_Dave »
I don't have experience with using this stuff on nylon, but i was the only thing I could get to bond an old plastic TRC Stealth antenna that was broken in two. I tried a few glues and two-part epoxies, but nothing worked except the Plastic Bonder.
https://www.loctiteproducts.com/en/products/build/epoxies/loctite_plasticbonder.html
Users browsing this forum: User avatarscr8p, User avatarXLR8 and 4 guests
