Stealth tranny question
So the question here is durability. I'm looking at a trinity d5 flatliner motor for my car. It's the 8 turn version and It's brand new. My question is if my first generation stealth transmission will handle the power and torque of the motor? I don't want to ruin my new transmission. What about my 3/16" cvd axles? I've read that with a heavy car and a powerful motor that smaller axles can twist/break from the load. Can this happen? What about in the grass and dirt?
Just wanted some opinions here because I dont want to damage my car again. Any ideas?
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Stealth tranny question
The tranny will support it no probs as long as built properly. It ain't much different from any more modern stealth, barring the slipper really. It will wear out faster obviously though.Dave145 wrote:So the question here is durability. I'm looking at a trinity d5 flatliner motor for my car. It's the 8 turn version and It's brand new. My question is if my first generation stealth transmission will handle the power and torque of the motor? I don't want to ruin my new transmission. What about my 3/16" cvd axles? I've read that with a heavy car and a powerful motor that smaller axles can twist/break from the load. Can this happen? What about in the grass and dirt?
Having said that, an 8turn mill in a 2wd is utter nonsense... actually an 8T mill in ANY car is nonsense unless you're drag racing...
Paul
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
X 2 with Paul- we ran 8x1-8x4 in Dirt Oval EDM's with perfectly balanced and trued featherlight foam tires and bodies that sucked the cars to the clay and they were still able to go from 0-150' in less than a second. If you ran that with buggy or rubber tires your going to tear up all sorts of things from outdrive bearings (heavy vibrations) to idler gears to spurs- don't do it!
Okay so how about a team Orion 10x2 motor with the same stealth tranny and car? Would a 10x2 not provode enough torque to go through medium length grass? I thought the double wind motors were really only for pavement or hard dirt or clay. Would this be a good motor for my car ?
A 10 turn is still a very hot 2wd wind- the difference in single/double/triple/quad winds are initial torque. You can run a 10 if your easy on the throttle, a nice 15 turn and you could really enjoy it IMO-
Ok I get it now. I have an older yokomo 14x2 motor from I believe the 80's or 90's. It's been through a lot of cars and car fires (stupid mechanical speed control) lately and is in rough shape. The timing ring is burnt, the brushes are at less than 1/4 of a brush lefy, the springs are weak, etc. The motor used to run great, bit now it has lost most of ots power and is slower than my 22 turn kyosho mega motor. What do I need to do to the motor to make it run like new again? Also how do i know how to set the timing. After a crash the endbell shifted from its original position this messing with the timing, so how do i know what timing position is best for my racing application?
Two quick things- new brushes and springs. Also you might very well just drop that armature into one of the other Mod cans
A new can?? I would be more worried about the armature being burnt from the heat even though it looks just fine to me. So would any mod can work? This motor looks to be about the size of I believe a 380. I'm not really sure. Also how would I handle timing the motor again? The timing Is already set wrong, so how would i reset it or adjust it properly?
- 1228 Views
Last post by Erich Reichert
- 699 Views
Last post by Lowgear
- 394 Views
- 2517 Views
Last post by Whiskers
- 891 Views
Last post by henry
- 31 Replies
- 3124 Views
Last post by Caine
- 987 Views
Last post by Bugle
- 21 Replies
- 1961 Views
Last post by knucklebuster
Google Adsense [Bot] and 7 guests
