B4 Wheels?
dvalleli
B4 Wheels?
Post by dvalleli »
So I've been trying to figure out a way to use B4 wheels on the old RC-10. After reading a bunch of posts here, it seems like there is no easy way to do the rears. I don't really want to buy old used (or new for that matter) B2/B3 wheels, as they are basically obsolete. I'd like to use the latest and greatest, so replacements are easy to come by.
The front wheels don't seem to be an issue - #1 the axles would be really easy to make on a lathe, and 2) I think someone mentioned that T3 or T4 axles will work with the wider offset of the modern wheels.
The rears are another story... I could fabricate custom axles, using the 1/4" stock bearings and new 3/16" wheel mount design. Is there a simpler, off-the-shelf-solution to using B4 rear wheels?
Thanks,
Dave
Re: B4 Wheels?
Bugle
Re: B4 Wheels?
Post by Bugle »
Yeah if you don't mind using non standard arms then the dynotech arms are the way to go. But I don't think there's any off the shelf parts that will let you run B4 rims with stock arms.
I had mine using standard arms and truck hub carriers with custom axles that were about 8mm longer with spacer to get the wheel to sit out.
Another way would be to make some hub carriers which put the bearings out to where they would be on a B4 then you could use B4 axles and driveshafts.
dvalleli
Re: B4 Wheels?
Post by dvalleli »
Thanks guys. I think for now, I will just fab some custom axles. When I get a few bucks, i'll look into the Klein arms (do they come in black?) and some B44 CVDs.
gregm
Re: B4 Wheels?
Post by gregm »
dvalleli wrote:Thanks guys. I think for now, I will just fab some custom axles. When I get a few bucks, i'll look into the Klein arms (do they come in black?) and some B44 CVDs.
No black. They can be dyed though.
dvalleli
Re: B4 Wheels?
Post by dvalleli »
hmmm - I have access to a machine shop, and plenty of black delrin :)
Users browsing this forum: No User AvatarDual and 15 guests
