What are these wheels?
I've got these front wheels that I have no clue what they are...
The one with the metal square I've seen on this board before. Are these Yokomo? Are they Nylon? Can I dye them? I suppose they fit as front RC10 wheels and tires?
The other front wheels are very weird. The picture is not so good sorry. The hole is very small and there is no place to put bearings on them... On one side, the hole is bordered by a star shape as if they were to be mounted on a driving axle... I mean as if they where used for traction (4WD) instead of passive front 2WD wheels.
I have never seen this before....
- Attachments
- yokomo1.jpg (154.72 KiB) Viewed 1453 times
- yokomo2.jpg (152.27 KiB) Viewed 1453 times
- star wheel 1.jpg (150.61 KiB) Viewed 1453 times
- Star wheel2.jpg (153.6 KiB) Viewed 1454 times
- star.jpg (26.83 KiB) Viewed 1454 times
- terry.sc
- Has thanked: 7 times
- Been thanked: 137 times
The wheels with the alloy adapters are Yokomo wheels. The adapters appeared after the 1989 worlds, when Yokomo came out with the 2.2" wheel and tyre. For a short while the only way to run 2.2" tyres was to use Yokomos wheels, even after other companies started making 2.2" wheels the Yokomo ones were still popular, especially with Associated drivers using a Yokomo in 4wd as by using adapters you only need one type of wheel.
They can be dyed as they are nylon.
- Eau Rouge
- Been thanked: 5 times
Yeah, it's a Losi 2wd front. The cars had spindles on bearings so that you didn't have to replace front bearings in each set of fronts you ran. Cool idea, but no one else uses anything like that, so the wheel is good for Losi 2wd cars, and that's it.
They still use that style wheel on current 2wd Losi XXXCR buggies, too.
Re: What are these wheels?
thoes losi fronts are the wheels that we use at birdsboro on the rear for schumacher stagger rib tires all around. they can be used with losi street weapon hex adapters on the rear. the adapter is like a 3/8 or 9.5 mm hex.its a hard adapter to find since they stopped making them and i think we used just about all of them i forget the part #. they re relased them but they are thinner then what they used to be. the wheels also came in a 5 star version also.
- templeofspeed
- Has thanked: 3 times
- Been thanked: 32 times
What happened, Jim? You seem to have lost your old self... New board layout getcha?BEAR_1 wrote:YGPM, GRIZZLY
- 19 Replies
- 2491 Views
Last post by shirochanwrx
- 29 Replies
- 4795 Views
Last post by hugger19
- 1237 Views
Last post by Claymore5150
- 1555 Views
Last post by JK Racing
- 1009 Views
Last post by Jay Dub
- 918 Views
Last post by popboy905
- 1083 Views
Last post by dvalleli
- 859 Views
Last post by mrlexan
Users browsing this forum: GoMachV,
R6cowboy,
sixdub and 4 guests
