best lead tape to balance wheels? fixing warped wheels?
- littleVETTE
- Has thanked: 6 times
- Been thanked: 10 times
i ran out of lead tape, and i was wondering what you guys use to balance your wheels. i've seen all kinds of crap to balance wheels. screws, coins, nuts, hood pins, pistons, washers, broken keys, gobs of glue, and a parents kid tooth. from your personal experiences what did you guys find that worked best?
also, has anyone tried fixing their warped wheels? any special tools that you made or found to straighten your wheels? or a process you go through to fix the problem? something like hot water or maybe using a heat gun, something along those lines.
Re: best lead tape to balance wheels? fixing warped wheels?
I have a box of wheels/tires to balance. I am thinking about using bits of masking tape or model clay but, I like the tooth idea now, just have to hold the kid down.
- littleVETTE
lol, i couldn't stop looking at it when i saw. what he told me was that his kids tooth fell out and thought it would give him luck that night.
- littleVETTE
they're associated. every once in a while i'll get one set that has a warped wheel. i freaking hate that.
- Eau Rouge
- Been thanked: 5 times
Elmers white poster tack putty on the inside of wheels. Simple, cheap and you can remove it if you want to re-balance later.
- littleVETTE
have you tried it doug? that's much better than chucking the whole tire and wheel away.
- Eau Rouge
I have a stack full of XXX race wheels/tires on a shelf all balanced with white poster putty. It works great.
- Eau Rouge
I have used the blue and white poster putty before, with different results. The white has a bit less tack, so it attracts less dirt, but the blue sticks better to slick surfaces. Either way, it's a good, inexpensive solution for balancing.
- Been thanked: 12 times
I have been using shoe-goo or silicone sealant type stuff to attach weights. Once it dries it doesn't really attract dirt, and is fairly easily removed if need be. For actual weight it depends on the size of the wheel and how out of balance it is. sometimes a small 4-4o nut, but some wheels need a bunch of lead. I have used the lead bars that the hobby shop sells for pinewood derby racers. Cut to size with strong side cutters and simply add or remove bits of it to fine tune.
one of the hardest tires to balance is schumacher minipin blue 2.2 truck tires. they are severly off balance and often have lots of mold flashing around the center where the two halves meet. they would vibrate so much it would shake the whole truck on or off the track. also when they stuff them in the bag to tightly they sometimes come out with flat spots. i would use standard hobby shop magnet tape on the inside of the rim to balance them out either the 1/2" or 1" wide tape cut into 1" strips depending on how bad they were. it is eaiser to use then lead tape and i never lost one yet, it removes eaisly with a small screwdriver and leaves little residue behind.
- littleVETTE
i noticed that you guys with the warped wheels still balance them. it's interesting to see that you guys just stuff them with a crap load of weights. no one has tried straighting them?
- bully
- Been thanked: 6 times
Much more racing lead wheel tape is the go mate
How about hot glue from a glue gun?
I haven't balanced any rims for a while, but I've been thinking that hot glue would be the way to go in future. Just dab little beads in the inner rim until they are balanced, and they should pull away cleanly when it is time to remount tires in the future.
- 676 Views
Last post by XLR8
- 29 Replies
- 4903 Views
Last post by hugger19
- 1282 Views
Last post by Claymore5150
- 1584 Views
Last post by JK Racing
- 1019 Views
Last post by Jay Dub
- 621 Views
- 616 Views
Last post by fordtransman
- 978 Views
