Traxxas TRX-3 rebulit , (bulkhead #2630)
korreka
Post by korreka »
This is my Traxxas TRX3 buggy:
the front suspension bulkhead (part 2630) was broken.
This part is quite difficult to obtain due to the age of the buggy and the fact that it frequently breaks in jumps or collisions - it is in high demand. In this picture you can see the wishbones, bulkhead, axles and other elements of the front suspension:
There is another Traxxas black bulkhead part, ref. 2530, from the Bandit buggy that is wider. It has the holes marked in red in the same relative position and the part would have to be cut along the yellow lines to make it an alternative.
Once it has been cut, it is screwed on since the 3 holes on each side match in relative position on the chassis, subframe and lower arm.
This photo shows the alternative bulkhead compared to the original.
We place the suspension tower and lower arms. With the chassis and subframe screws, the bulkhead is firmly attached, but the halves are joined in one piece with epoxy adhesive as seen in the picture:
Finally, just 2 more holes need to be drilled in the bulkhead for the bumper:
In the following pictures, the final appearance of the buggy with the vintage electronics:
* Sanwa SRC-2322RS 40Mhz receiver
* Sanwa SM-102 servo
* LRP Ics 8066 75A electronic speed controller with XT60 connector
* Kyosho Kspeed 15T motor.
This TX3 rebuild can be translated into Spanish here: https://reparar-cochesrc.blogspot.com/2024/03/Traxxas-TRX3.html
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: Traxxas TRX-3 , bulkhead repair (#2630)
Post by RC10th »
Not a bad idea, I would use slightly longer hinge pins and a tie bar like most other vehicles.
TRX-1-3
Has thanked: 2066 times
Been thanked: 992 times
Post by TRX-1-3 »
Excellent description and pics! Thank you!
Mango
Has thanked: 33 times
Been thanked: 15 times
Post by Mango »
Necessity is the mother of invention, it is definitely a nice looking buggy.
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Post by LowClassCC »
A hot stapler would help add structural support to the area of the bulkhead that was cut.
Return to “Traxxas Forum”
