Traxxas TRX-3
- Dangeruss
- Has thanked: 425 times
- Been thanked: 1405 times
Traxxas TRX-3
In 1993 Traxxas' continual improvement to their 1/10 2wd racing buggy program would result in the TRX-3. Unlike its Blue Eagle LSII stablemate whose updates centered around its double deck chassis, the TRX-3 was a nearly all-new buggy. Sharing very few parts with the previous TRX-1 Traxxas' would take a diametric approach to the spec creep that created increasingly larger buggies by introducing one that was smaller in nearly every physical dimension in order to produce a more nimble platform. This started with a .5in shorter, double deck, black fiberglass chassis plate with improved steering bellcranks sandwiched under the top deck that stretched from the detachable .125in narrower 30-degree plastic front kick up back to its chassis stiffening plastic battery box. The suspension was still a 4-wheel independent, lower a-arm and turnbuckle upper camber link design but the front arms were each .2in. shorter and .125in closer than on the TRX-1. The rear arms, mounts and stub axle housings where unchanged however new caster blocks were fitted up front. The suspension attached to revised front and rear bulkheads which supported a pair of black fiberglass shock towers holding teflon coated hard anodized aluminum oil-filled shocks, with medium length coilovers on the nose and extra-long coilovers at the tail. The TRX-3 would also feature a redesigned 3-gear externally adjustable ball diff transmission that moved the motor further forward on its new aluminum mount and the outputs downward for better weight distribution and driveshaft angles. Disk face wheels would supplant the TRX-1 spoke wheels and wear Pro-Trax 4740 ribbed front and new 4751 mini pin rear tires. A more traditionally styled lexan buggy body would complete the TRX-3, which came unassembled, with full bearings, less electronics:
Factoid... why was there no TRX-2? Because the TRX-1 was released in 199(1) and the TRX-3 was released in 199(3).
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Re: Traxxas TRX-3
Another Traxxas bedtime story
How many kids would dream of having that under the Christmas tree.
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2976 times
Re: Traxxas TRX-3
I haven't driven my TRX-1 or TRX-3 yet, but the TRX-3 looks to me like it got heavier and took a step back from being a pure racer. That's my impression at least based on design impressions.
- Dangeruss
Re: Traxxas TRX-3
What caused you to think it took a step back from being a pure racer? The addition of the extra plastic from the battery box and the front deck seemed like a step back to me.Frankentruck wrote: ↑Tue Aug 13, 2024 5:34 pm I haven't driven my TRX-1 or TRX-3 yet, but the TRX-3 looks to me like it got heavier and took a step back from being a pure racer. That's my impression at least based on design impressions.
"All I want for Christmas is a TRX-3, a TRX-3, gee if I could only have a TRX-3, then I could wish you Merry Christmas...."
...Sleep tight
- Frankentruck
Re: Traxxas TRX-3
It seems like a step back to me because:Dangeruss wrote: ↑Tue Aug 13, 2024 11:59 pmWhat caused you to think it took a step back from being a pure racer? The addition of the extra plastic from the battery box and the front deck seemed like a step back to me.Frankentruck wrote: ↑Tue Aug 13, 2024 5:34 pm I haven't driven my TRX-1 or TRX-3 yet, but the TRX-3 looks to me like it got heavier and took a step back from being a pure racer. That's my impression at least based on design impressions.
- All that extra plastic added for the TRX-3 battery box and then a top deck on the plastic is just more weight with no benefit.
- My TRX-3 chassis is natural color fiberglass chassis with separate plastic piece for front kickup. TRX-1 is graphite chassis with front kickup.
- Dangeruss
Re: Traxxas TRX-3
Yep, I'd call that a consensus.Frankentruck wrote: ↑Wed Aug 14, 2024 5:50 am
- Has thanked: 51 times
- Been thanked: 108 times
Re: Traxxas TRX-3
Do I hear Composite Craft?
Dangeruss wrote: ↑Wed Aug 14, 2024 1:57 pmYep, I'd call that a consensus.Frankentruck wrote: ↑Wed Aug 14, 2024 5:50 am
.How cool would the car have been with a molded kickup graphite chassis, battery cups instead of the battery box, and a graphite top deck that stretched front to rear...
*** POWDER - KING ***
- Dangeruss
Re: Traxxas TRX-3
I can't be sure, but I think I hear my Traxxas' whispering it, gently in the night...
Re: Traxxas TRX-3
Nice car! Trying to find one these days is a mission. Pity they didn’t carry on the platform.
- 1443 Views
Last post by Brendan2904
- 1202 Views
Last post by rnoswal3434
- 40 Replies
- 9069 Views
Last post by Carmac
- 2237 Views
Last post by mrlexan
- 2838 Views
Last post by Lonestar
- 443 Views
Last post by Dangeruss
- 24 Replies
- 6179 Views
Last post by TRX-1-3
- 27 Replies
- 4884 Views
Last post by rctenracer
