Differences between B2 and B3?
- Has thanked: 3 times
- Been thanked: 13 times
I don't know if there is a thread about this somewhere, but what are the differences between the b2 and b3? They look very similar to me and I know there was a b2 to b3 conversion kit back in the day.
RC10 B3 / RC10 B6.1FL / RC10 B64D / RC10 B74.1D / RC10 T2 / RC10 T6.1
Re: Differences between B2 and B3?
check the 25yr thread for lots of details of difference between b2 and b3.
A BUTTLOAD of info so be prepared
https://www.rc10talk.com/viewtopic.php?f=35&t=13059
shorter answer: front and rear arms, c hubs, spindles, rear hubs, slipper, front and rear shock towers,trans plate, top plate, rear arm mounts.
- MarkyDents
- Has thanked: 1809 times
- Been thanked: 643 times
I pulled these from another thread a ways back, scans from RCCA.
Hey Cru ! Go balls out
So basically a B3 is just an updated version of a B2? like a B2.1 kind of thing
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
If you change everything except the shocks and part of the transmission, is it really?
Its not like its a major change, its all geometry changes.juicedcoupe wrote: ↑Thu Jun 09, 2022 3:25 pmIf you change everything except the shocks and part of the transmission, is it really?
- juicedcoupe
I understand that there is a lot of compatibility, but they nearly changed everything.RustyBall wrote: ↑Fri Jun 10, 2022 1:41 pmIts not like its a major change, its all geometry changes.juicedcoupe wrote: ↑Thu Jun 09, 2022 3:25 pmIf you change everything except the shocks and part of the transmission, is it really?
The B2 and B3 probably have about as many common parts as the B2 and the Team Car/Worlds cars do. Nearly everything is an evolution of its predecessor.
- Has thanked: 36 times
- Been thanked: 1318 times
If the B3 didn't share so many parts with the T3, I could see a B2.1 argument.
The same could be said about the 10T and T2. They share a whole lot more than the B2 and B3 do.
Yes, but if the T2 was just a 10T.1 than the T3 would have been the T2. Then it would make sense as a B2.1.
The B2 and B3 are like a B6 and B6.3 the parts are just updated for geometry changes. The arms, towers, chassis, slipper, bearing carriers etc. have all been changed for geometry.
They changed the geometry of the parts. Like a B6 to a B6.3... Its not an entirely different car... Associeted made a conversion kit to go from a B2 to B3. So it would be just as easy to go from a B3 to B2. Most of the parts are compatible just different geometry.juicedcoupe wrote: ↑Fri Jun 10, 2022 5:25 pm
Thankfully, they didn't do all of that ".1 .2" crap back then.RustyBall wrote: ↑Fri Jun 10, 2022 7:40 pmYes, but if the T2 was just a 10T.1 than the T3 would have been the T2. Then it would make sense as a B2.1.
- juicedcoupe
If you count all the versions of the original RC10, wasn't the B2 like the 10th iteration?
The Worlds car could have been the RC10.9
At any rate. I'm of the opinion that if you have to change nearly everything to get to the new version, it is a different model.
And yes. I understand that many parts are cross-compatable between the two and that hybrids are possible. But in their complete iterations, there are just too many differences for me.
- Regular Member
- Has thanked: 6 times
- Been thanked: 5 times
Seems to be lots of differences but a good read for me as I will happily take a B2 or B3 or a B3 converted as I know these are getting thin on the ground!
- 3358 Views
Last post by uzzi
- 33 Replies
- 3685 Views
Last post by Brat
- 950 Views
Last post by porsche4bangers
- 122 Replies
- 43216 Views
- 2045 Views
Last post by slow_jun
- 21 Replies
- 2648 Views
Last post by Phin
- 3584 Views
Last post by harold996tt
- 766 Views
Last post by markt311
