Yr4 differences
Yr4 differences
i see there are yr4m and j type. etc... What are the main differences. .?
Also are the drive trains similar to the buggy
I have had an 870,94 pavidas, and works 93. .. Just want something im familar with
- stickboy007
- Been thanked: 55 times
Re: Yr4 differences
I'm pretty sure the M2 type J uses 33T diff pulleys which are compatible with the '94 YZ10 and Pavidis editions. The main commonality between the YR4 and YZ10 is in the drivetrain (layshaft, diff pulleys, bulkheads), although I do not know with certainty which YR4 model began the switch from 35T pulleys to 33T pulleys.
- littleVETTE
- Has thanked: 6 times
- Been thanked: 10 times
Re: Yr4 differences
where to begin? some early yr4's had ridiculously thin chassis's. then there's the bulkheads, outdrives, belts, center bulkheads, shock towers, top plates, belt tensioners, shocks, carriers, spindles, etc... it was an interesting evolution for the yr4. try out this site. it's not complete, but it gives you an idea what the parts went through and the changes.
http://www.rcracing.com/Page.cfm?InfoID=846
Re: Yr4 differences
Have a question,so the bulkhead of a yr4 m2 would fit a yrm4 right?
Pic borrowed from a member here.
Am i correct to assume this?
― Confucius
― Confucius
- littleVETTE
Re: Yr4 differences
i'm not sure what you're asking, but check out page 7 in the PRO manual. that should give you an idea what it looks like...
http://www.competitionx.com/pdf/vehicle-manuals/yokomo-yr4-m2-pro-manual.pdf
Re: Yr4 differences
thanks for the link, seems they are the same, maybe just the kickup degree.
― Confucius
― Confucius
Re: Yr4 differences
Hi Guys,
need your help again, need to confirm if the swing shaft (universal) for the YR4 front and rear are the same length? meaning I can use either front to rear and VV?
will the ZR 010H fit the YR4 Front?or rear?
ZR-010
ZR-010
― Confucius
― Confucius
Re: Yr4 differences
nvm, found my answers. thanks.
― Confucius
― Confucius
- 1348 Views
Last post by Triniboy
- 987 Views
- 20 Replies
- 3005 Views
- 1129 Views
Last post by Mr. ED
- 1512 Views
Last post by hairymuffin
- 1062 Views
Last post by Justjoe
- 31 Replies
- 6319 Views
Last post by OldSkoolRC
- 1124 Views
Last post by Mr. ED
Users browsing this forum: DotNetDotCom.org [Bot] and 3 guests
