Guys I have a DS. What ball joints and turnbuckles are compatible with it? I need the steering rods.
Thanks
Max
Ball joint’s and turn buckles
- MarkyDents
- Has thanked: 1809 times
- Been thanked: 643 times
Re: Ball joint’s and turn buckles
Hey Cru ! Go balls out
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
The original steering links were 1", according to the manual. Depending on the ball cups used, you might need an even shorter one.
CRC 1231 cups look identical to original AE cups, if you can find them. Unless you get lucky, original (short) AE cups are becoming harder to find and tend to be expensive.
I don't know if the DS has the same space limitations as the buggy, but the buggies are known to have interference problems when using bulkier ball cups ( like RPM).
- 1295 Views
- 1352 Views
Last post by vintage racer
- 1088 Views
Last post by ChisaiKuso
- 406 Views
Last post by juicedcoupe
- 2491 Views
Last post by toybaron
- 2510 Views
Last post by AYKBOBCAT
- 2359 Views
Last post by JK Racing
- 574 Views
Last post by i crash cars
