What hinge pins,turn buckles and other modern parts fit RC10
- vintage racer
Im trying to finish some builds and hoping someone here can tell me where to buy hinge pins and turn buckles for my RC10.Surely they are the same as some modern cars.I also need shock ends with the hex ball,ball studs and ends.So where do you guys get your hardware?Im having no luck on ebay.Any help really appreciated.
- vintage racer
Re: What hinge pins,turn buckles and other modern parts fit
Im guessing no one here builds RC10s?I found some FT blue turnbuckles,just hope I ordered the right lengths,also RPM ball cups.No luck with hinge pins or shock ends.
- Has thanked: 1129 times
- Been thanked: 3919 times
Shock ends?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2965&P=7
Hinge pins?
Outer front
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2528&P=7
Kingpin
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2526&P=7
Outer rear
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2566&P=7
Inner rear for newer arms (worlds era)
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2936&P=7
Ball joints
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2546&P=7
Turnbuckles
Before I go google searching I need to know which version your building so I can look at the manual, get the lengths, and go to tower and get links for you.
The short answer to your question, yes- we build rc10's here. The problem is your being to general. I don't know if those inner rear pins will fit, because you didn't say what arms your using. Same with turnbuckles.
Hinge pins?
Outer front
Kingpin
Outer rear
Ball joints
Turnbuckles
- vintage racer
Thanks for the links,Ive been out of RC for a few years and completely forgor about tower.The 2 cars Im building are stock wide arm,one grafite with andys arms,the other black tub with RPM arms,The turn buckles I ordered are 16.54 long,I got 4 of those and 2.01,I got 2 of those.I spent all day searching the net yesterday to come up with that so hope Im right.Im not the best on computers.I still need the bell crank link and servo link but not sure on lenth?
For the bellcrank link you can use the rpm one piece, they work great and should be available on eBay. They are officially discontinued but just recently
Here are the manuals, if you click on the right one and look at the turnbuckles it should show the lengths. This way you can look them up for any and all combinations
http://www.competitionx.com/rc-manuals/cars-and-trucks-t-z/team-associated-manuals/
- vintage racer
- 1295 Views
- 629 Views
Last post by juicedcoupe
- 748 Views
Last post by blubblood
- 567 Views
Last post by JK Racing
- 1155 Views
Last post by 8rad
- 1172 Views
Last post by sandkil
- 890 Views
Last post by PBR Allstar
- 1600 Views
Last post by LoboNYC
Users browsing this forum: Bing [Bot] and 2 guests
