need dual ball joint shocks for my ayk 566b
Hi
I'm working on restoring a AYK super trail. I will likely make a shock tower for the back and use a different setup in the front. I think I need shocks in the rear that would have dual ball joints (at the shaft and at the shock cap).
Does Tamiya have those? About the size of front shocks for the RC10 (original) would do. Metal if possible.
Thanks for any help...
Re: need dual ball joint shocks for my ayk 566b
Kyosho platinum shocks have a metal ball on top. Also, Tamiya cva shocks for the ta01 and ta02 cars will accept a metal ball stud both top and bottom. The Tamiya shocks I speak of are plastic, but theres probably a metal upgrade for big $$. To get some controlled side to side movement from a kyosho gold shock I have used silicone fuel tubing as a sleeve in the upper shock hole,, over the screw that would secure it to a shock tower. The flexible tubing allows some movement, yet keeps things tight and slop free.
I have used the tubing trick too. I'm hoping for something with a ball joint though. I will look into those. Thanks
I am also wondering what lenght are the RC18 shocks. The 566b uses quite small shocks... There might be something that would be a direct fit but that would work better than the stock ones.
- Been thanked: 325 times
3Racing shocks have 4.8mm captured balls in the caps & shock ends, and come in a wide variety of sizes. They work very well, but might need lighter shock oil or the holes opened up a bit in the piston rings to make them work better in a 1:10 offroad car. They're cheap as dirt, too.
http://os.3racing.hk/products.php?products_key=2607
I used these on the Marui Galaxy I restored for my brother (65mm front & rear) and the Lazer ZX-5 damper set for the CYANide Optima.
Can you describe how the 3 racing shocks are sealed? I would love to find a source for good shocks as long as they are not sealed like old optima or progress shocks.
Good point. I bought similar shocks in the past (can't remember the brand though) and they leaked quite a bit.. Are those well sealed?rccars4sal wrote:Can you describe how the 3 racing shocks are sealed? I would love to find a source for good shocks as long as they are not sealed like old optima or progress shocks.
I also found that TL-01 shocks should work fine in the back for the 566. They are 50mm. That's 2-3mm too long for the font though. They would fit in the front with a new mounting hole on the chassis rail. I'd like to find a direct fit for the front but I doubt I'll be able to find shocks that match for the front and rear without mods.
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
You´re not really considering tamya plastic shocks on an Ayk 566BAYKBOBCAT wrote:I also found that TL-01 shocks should work fine in the back for the 566. They are 50mm. That's 2-3mm too long for the font though. They would fit in the front with a new mounting hole on the chassis rail. I'd like to find a direct fit for the front but I doubt I'll be able to find shocks that match for the front and rear without mods.
Gone fishing
DennisM wrote:You´re not really considering tamya plastic shocks on an Ayk 566BAYKBOBCAT wrote:I also found that TL-01 shocks should work fine in the back for the 566. They are 50mm. That's 2-3mm too long for the font though. They would fit in the front with a new mounting hole on the chassis rail. I'd like to find a direct fit for the front but I doubt I'll be able to find shocks that match for the front and rear without mods.![]()
Nope... got these instead. They are 1-2mm close to the original ones so I figure they would work... I just need to figure a way to make the top ring "flexible" a bit. I'm thinking of sandwitching it in between conical washers or something like that...
http://www.ebay.ca/itm/ALUMINUM-SHOCK-DAMPER-S-TEAM-ASSOCIATED-RC18T-RC18B-RC18R-RC18MT-RC18-RC-18T-18B-/380440614181?pt=Radio_Control_Parts_Accessories&hash=item5894071525
Looking at some assembly diagrams online, and from memory--I believe they have a clear diaphram similar to the Kyosho Golds in the shock cap, and each shock has two 3mm O-rings on the shock shaft. I've built 8 of these in total and none have leaked.rccars4sal wrote:Can you describe how the 3 racing shocks are sealed? I would love to find a source for good shocks as long as they are not sealed like old optima or progress shocks.
$105.00 ?!?
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
I hear ya those dampers are pricy.Coelacanth wrote:$105.00 ?!?
Yeah.. All things being equal, r/c parts are much more expansive than 1:1 parts...
- 2490 Views
Last post by toybaron
- 5816 Views
- 1088 Views
Last post by ChisaiKuso
- 1775 Views
Last post by TomEG
- 4304 Views
- 626 Views
Last post by juicedcoupe
- 406 Views
- 27 Replies
- 5783 Views
Last post by Dadio
