modern yokomo big bore shocks
- bully
- Been thanked: 6 times
Anyone who runs modern yokomo x shocks know how to get the o rings separately? I have only seen the shaft o rings and adjustment nut o rings available separately but not the top caps and bottom caps.. I have looked at the team associated big bore rebuild kits wondering wether they would work for the top and bottom caps,and I can just use the yokomo shaft o rings.... On the yokomo shaft o rings what are most people using the clear whitish or the blue ones? Thanks everyone..
- stickboy007
- Been thanked: 55 times
Re: modern yokomo big bore shocks
You should measure the diameter of the shock shafts. Chances are, they are 3mm shafts, in which case you can at least use AE or Kyosho o-rings. As for the adjustment o-ring, if the shock body diameter matches that of other big bore shocks (and I suspect it would), then the same answer applies here as well.
- bully
Shaft and adjustment o rings are not what I was asking about mate.. I asked about the top and bottom cap o rings
- stickboy007
Oops. Well...all big bores are the same diameter, right? I would expect all of the o-rings to be the same size.
- works92
- Has thanked: 85 times
- Been thanked: 32 times
you're right, yokomo doesn't sell separetly the top and bottom caps o ring.
personaly i'm just re-using the originals ones with some green grease and they're not leaking.
for the shaft o ring , i use to put the whitish, but with the new bottom caps i'm gonna test 1blue and 1whitish per cartridge.
- bully
Yeah thanks mate I am gonna get the v2 upgrade for the bottom cap myself when I get some spare coin.. Thanks for sharing about the shaft o rings mate.
- 1267 Views
Last post by adam lancia
- 958 Views
Last post by fredswain
- 1138 Views
Last post by janaya
- 1151 Views
Last post by BustedJellybean
- 2163 Views
Last post by Lonestar
- 1986 Views
Last post by JK Racing
- 804 Views
Last post by pumpkinfish
- 982 Views
Last post by askbob
