12mm Big Bore shock help
rem270
Post by rem270 »
I bought a set of shocks but don't know how to put them together :oops: I have looked for a video on you tube and looked for better instructions that cam with them but can't find anything. I just don't understand the instructions that came with them. is there any thing out there that you guys know of? thanks for the help.
Has thanked: 356 times
Been thanked: 470 times
Re: 12mm Big Bore shock help
This is a vintage site, but I have a few pairs of them- what don't you understand and I might be able to help-
rem270
Post by rem270 »
Charlie don't surf wrote:This is a vintage site, but I have a few pairs of them- what don't you understand and I might be able to help-
I just don't know in what order they fall in. in the fist pic it shows a nylon spacer going in the shock shaft but the next pic it dont show it no more but shows all the other peaces in what order they go in but don't talk about that first spacer.
There are two "lipped" washers, they are the first and last parts of the "cartridge" for the shock, they go like this..
1) take an old AE shock tool (the plastic thing to seat and remove the seal set)
2) put the lipped washer on first, slide it all the way on the tool
3) then the o ring
4) next the thick washer
5) then another o ring
6) then another lipped washer, but both times the larger diameter of the lip needs to be closest to the o ring
7) then install by placing the completed set into the base of the shock body (bottom)
8) remove the tool and keep the set in the base
9) install the large black seal o ring
10) install the end cap
rem270
Post by rem270 »
Charlie don't surf wrote:There are two "lipped" washers, they are the first and last parts of the "cartridge" for the shock, they go like this..
3) then the o ring
Thanks a million :D
askbob
Post by askbob »
While on the subject... Do the big bores use the same size O-rings as the V2 shocks?
Users browsing this forum: User avatarGoMachV, User avatarjuicedcoupe and 5 guests
