Big bore shocks.
Big bore shocks.
I know someone has probably asked before but what shocks off the new associated models will fit the rc10t? Are they bolt on or do I need to make modifications?
- Been thanked: 498 times
Re: Big bore shocks.
same applies to this as the world car. Need to check the lengths of the big bores as compared to the rc10t shocks and use spacers where needed to adjust for clearances.
- jeepy2013
- Has thanked: 15 times
- Been thanked: 4 times
The T4.2 Big Bores are a direct fit, just need appropriate spacers / shims to shim them away from the tower, etc.
Part # 91315 (front)
Part # 91317 (rear)
Part # 91317 (rear)
- Lonestar
- Has thanked: 623 times
- Been thanked: 170 times
watch out the front end with BB - as you have to space the top further away from the shock tower, they're beginning to work the wrong angle from the bottom (which can't be spaced), which is even worse as the suspension is compressed. I don't BB's to check on one of my 10T's but I'm thinking there's gonna be some bindin' in there.
Not an issue in the back as you can space both top and bottom ends. Watch out for the body clearance, still.
- Been thanked: 19 times
What about shimming the shock tower back from the bulkhead? Not much, just enough to pull the shock back into better alignment.
Current:RC10T, T3 FT, GT Blue Tub, GT FT, GT2 FT, GT5, RC28, SC28, Micro RS4.
Previous:B2, B3, B3 FT, 10T pink chassis, GT FT, TC3, TC3 FT, RS4MT
Tamiya TA02, Thunder Tiger TS4N pro, Kyosho VoneR, Emaxx, MX4, MP 7.5, 7.5 Kanai.
yeah, just have to watch crashing into the bellcranks with the upper links. probably a funky two (or 3) part shock tower would get you where you need to be. short tower for the upper link balls that secures to a tower mounted behind it above the upper links.
- jeepy2013
I have the new style ( I think T2 & GT #7206) front arms on mine 10T runner, so spacing isn't a issue. I don't have a set of BB's right now, but seriously considering them for that truck since it will more than likely see some track time. Maybe mine is a frankentruck.
A better option might be to run these on the front.
https://www.teamassociated.com/parts/details/6468-ASC6468-rc10_shock_rod_ends/
- Lonestar
That's the stock 10T bottom ends... I don't think it will alleviate the issue. But then again, one has to try to see how it all nets out.RS Chris wrote:A better option might be to run these on the front.
- 1167 Views
Last post by adam lancia
- 928 Views
Last post by fredswain
- 1117 Views
Last post by janaya
- 1024 Views
Last post by BustedJellybean
- 1960 Views
Last post by JK Racing
- 1382 Views
Last post by bully
- 770 Views
Last post by pumpkinfish
- 958 Views
Last post by askbob
