MIP Aluminum Topshaft On a B3
MotoObscura
Has thanked: 45 times
Been thanked: 65 times
Post by MotoObscura »
Model number 12156. Will it work? For some reason it is in the b3 section of their site, but the product figment says it's for the b4 and sc10...
Nick DiVitto My current vintage racing lineup: Associated RC10 B2, RC10 Team Car, Losi XXT, RC10T, XX4, XFactory X5, Schumacher CAT 2000 www.moto-obscura.com My Youtube Channel
MotoObscura
Re: MIP Aluminum Topshaft On a B3
Well, I just ordered one for cheap on ebay, so when it gets here we'll do some science.
that won't work in a b3 trans case. the stock b4 topshaft has a separate spacer that goes on the topshaft when used in a b4 case. to use it in any other stealth case the spacer can not be used. the mip shaft has the spacer built in, so you can't use it.
you have to use a stock b4 topshaft (9601 or something like that) to use a modern slipper setup on your b3.
DHood
Post by DHood »
If you're dead set on a MIP you can have a machinist turn down the shaft "built in spacer". I just did one last week, Its pretty simple
MotoObscura
Thanks for the tip. I could probably figure it out and do it on my lathe
Users browsing this forum: No User AvatarAhrefs [Bot] and 8 guests
