TRX-1 gearbox topshaft question
- Been thanked: 4 times
I've got about a couple of dozen machined gearbox top shafts for the TRX-1 which allowed the use of the RC10T slipper clutch. Did any other Traxxas vehicle share this gearbox or topshaft? Blue Eagle?
Re: TRX-1 gearbox topshaft question
As far as I recall, the top shaft was the same for all the Magnum transmissions. The only thing that has changed over all these years is that the newer stuff uses the Revo-style slipper clutch and the shaft is different in the slipper area to accept the newer slipper. Even the newer VXL top shaft will work in the TRX-1 trans once you install the correct top gear and Revo slipper assembly. Everything from the TRX-1, TRX-3, SRT, Blue Eagle, Hawk2/Rad2, and 1st gen Rustler/Bandit/Stampede all use the same top shaft.fredswain wrote:I've got about a couple of dozen machined gearbox top shafts for the TRX-1 which allowed the use of the RC10T slipper clutch. Did any other Traxxas vehicle share this gearbox or topshaft? Blue Eagle?
With that said, STRC makes a top shaft for the Traxxas trans that lets you use the newer style Associated slipper/spur assembly. Probably a better option than the older 10T slipper. And it will work in the TRX-1.
It might be a better option but I've got a couple dozen of them in a bin that I need to get rid of.
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
harry697 nailed it. As far as vintageyness goes, a TRX rig with a 10T slipper would be pretty neat. Are these the Rayborn slipper components?
Yes . They use the early style slipper with the bearing but the later yellow slipper pad.
Using the same essential gearbox for basically 25 years now was smart of Traxxas. Once you get a gear design, there really shouldn't be any reason to change it or if you do change something, change only part of it.
- 766 Views
Last post by Jay Dub
- 26 Replies
- 2962 Views
Last post by Chewbacca
- 1384 Views
- 922 Views
Last post by a01butal
- 3262 Views
Last post by TomEG
- 1570 Views
Last post by Asso_man!
- 781 Views
Last post by markt311
- 1698 Views
Last post by Konich
