I'm going to do it on my 10T only way i can think of doing it is having a peice of steel bar drilled out to the right diameter then pushing it off using a g clamp or something similar.
Any other suggestions guys?
Yep, was just verifying 100% that it works with the stock 2.25 ratio stuff with no issueCharlie don't surf wrote:He has the RPM 2.65 conversion that uses a smaller top shaft to achieve that ratio-
Charlie don't surf wrote:Did you get that right from RPM? Last I knew they were in stock-
