It’s the other way around:Charlie don't surf wrote: ↑Sat Jan 14, 2012 5:46 pm No, the 2.65 topshaft is like 16t, the 1.95 is 20t and the stock 2.25 is 18t
No, Reggie has it right. The 2.65 trans uses the top shaft with less teeth. The 1.96 top shaft has more teeth.Chewbacca wrote: ↑Sat Jul 03, 2021 10:15 amIt’s the other way around:Charlie don't surf wrote: ↑Sat Jan 14, 2012 5:46 pm No, the 2.65 topshaft is like 16t, the 1.95 is 20t and the stock 2.25 is 18t
2.25 Standard: 20t
1.95. 18t
That is why the 2.65 grenades idler gears with todays modern electronics (less teeth engaged on idler= higher tooth load). A Steel gt idler helps, but then you blow teeth off diff gears if not swapped every race day. This is what i found racing 2wd mod truck fwiw.scr8p wrote: ↑Sat Jul 03, 2021 10:23 amNo, Reggie has it right. The 2.65 trans uses the top shaft with less teeth. The 1.96 top shaft has more teeth.Chewbacca wrote: ↑Sat Jul 03, 2021 10:15 amIt’s the other way around:Charlie don't surf wrote: ↑Sat Jan 14, 2012 5:46 pm No, the 2.65 topshaft is like 16t, the 1.95 is 20t and the stock 2.25 is 18t
2.25 Standard: 20t
1.95. 18t
