Sipper eliminators for the b4 topshaft 2.25
- Has thanked: 1243 times
- Been thanked: 639 times
Hey all,
I'm looking for a slipper eliminator for my 2.25 with a b4 stop shaft.
I know the b4 top shaft was used through the b6 but I am still having a hard time knowing what will work
I saw this part Part# CSW4465
https://www.amainhobbies.com/custom-works-direct-mount-spur-hub-csw4465/p-qtartauqbz2xactz But will the current b6.2 parts work, or has the top shaft changed enough that it's not applicable any more
https://www.amainhobbies.com/exotek-b6.1-b6.1d-direct-spur-gear-mount-slipper-eliminator-stock-top-shaft-exo1851/p-qtaltawqlb2xactz
Exotek B6.1/B6.1D Direct Spur Gear Mount Slipper Eliminator (Stock Top Shaft) would either work? what spurs would work?
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Re: Sipper eliminators for the b4 topshaft 2.25
I'm sure the B6 parts wont fit, but from memory exotek did make a slipper eliminator for the B4 series. Ebay will probably be your best bet since most things for the B4 are discontinued now.
That is the right call. I'll Just ordered the exotek 1942.
They have it in stock on their website with a $2.5 shipping fee.
http://www.exotekracing.com/dr10-db10-sc10-slipper-eliminator-pro-spur-mount/
What makes you sure the b6 parts don't work? I'm trying to understand what is changing across the lines. There appears to be a change from b/t 6 to b/t6.1. From the pictures it looks like its pin based again like the v1.
RC10B6.1 FT Vented Slipper Hub, outer
This part fits the following vehicles:
RC10B6.1
RC10B6.1D
RC10B6.1DL
RC10B6.2
RC10B6.2D
RC10B6.3
RC10B6.3D
RC10SC6.1
RC10SC6.2
RC10T6.1
RC10T6.2
From what I've seen the same v2 slipper plates work on the b5 and b6D that work on the b4
B44
DR10
ProSC10
RB10
RC10B4
RC10B4.1
RC10B4.2
RC10B5M
RC10B6
RC10B6 Club Racer
RC10B6D
RC10SC5M
RC10T4
RC10T4.1
RC10T4.2
RC10T4.3
RC10T5M
Reflex DB10
SC10
SC10 4x4
SC10B
SC10GT
SR10
Trophy Rat
- Has thanked: 36 times
- Been thanked: 1318 times
Pretty sure there's a difference between the b6 and b6.1 topshaft. Anything b6.1 and newer will not work.
Put the standard 2.25 top shaft back in it and get a hub from Dynotech.
https://www.dynotech-racing.com/partDetail.php?RefNum=4005D
For this build I'm keeping the b4 style top shaft. I had the CW eliminator and that would have been fine with the v1.scr8p wrote: ↑Fri Jul 02, 2021 1:52 pm Pretty sure there's a difference between the b6 and b6.1 topshaft. Anything b6.1 and newer will not work.
- Has thanked: 51 times
- Been thanked: 108 times
I can make you a fixed slipper with a classic top shaft and slipper unit if you’re interested.
I’ll trade you for the b4 top shaft.
Since you are not using a slipper anyway.
*** POWDER - KING ***
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
I think that he has an Avid aluminum shaft that he is wanting to use, not just simply remove the slipper.
- 797 Views
Last post by RichieRich
- 1857 Views
Last post by XLR8
- 979 Views
Last post by MotoObscura
- 549 Views
Last post by SteveK
- 28 Replies
- 2867 Views
Last post by Toasted Coastie
- 1462 Views
Last post by fredswain
- 1189 Views
