topcat narrow tract arms: how to tell?
- zoomzoombang
as I was looking through my topcat bits and bob, I realized that I have no clue whether it's got the narrow tract or stock item. Can anyone give me the length from the a-arm pivot pin to the pillow ball capture end. And what about the decreased castor hub, how would I be able to tell? Thanks.
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
Re: topcat narrow tract arms: how to tell?
Narrow track front arms are molded with part number T287 on the underside and measure 77mm overall. Standard arms measure 82mm overall.
As for the caster variation you'll find there are two different top suspension arms. The original have a square sharp finish while the revised and reduced castor items have a smoother finish and have part number T284 molded on the underside.
Hope this helps.
Cheers-Jason
Hope this helps.
Cheers-Jason
- zoomzoombang
Thanks Jason! Now where did I put my calipers...J.M. wrote:Narrow track front arms are molded with part number T287 on the underside and measure 77mm overall. Standard arms measure 82mm overall.
Hope this helps.
Cheers-Jason
- Bormac
Just have a look for those part numbers which will be on the underside of these parts. If they don't have any then it's a good bet you have the factory original bits.
- 807 Views
Last post by badhoopty
- 3121 Views
Last post by Chewbacca
- 385 Views
Last post by klavy69
- 1168 Views
Last post by RCveteran
- 2808 Views
Last post by DaveM
- 1639 Views
Last post by Badmuthatrucker
- 989 Views
Last post by cautrell05
- 1541 Views
Last post by Chris K
