gold pan: converting from narrow to wide front arms, parts?
resurrected my original narrow track gold pan, converted to brushless/lipo/DSM, but otherwise stock. it's mostly a basher unless my local track has a vintage class where i stand a chance at competing in racing. i haven't looked into it yet.
anyhoo,
i ordered up a set of stock wide track front arms, and the shock tower and some longer threaded rods for the upper and steering arms. what else do i need, or is that it?
-peter
anyhoo,
-peter
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: gold pan: converting from narrow to wide front arms, par
That's the basics. You can also go with the worlds caster blocks, aluminum on center axles and on center steering arms. Also the shocks will work but .71's would be better with the long arms.
I think I might order up some turnbuckles and center steer parts to finish this conversion to wide front.
I swear I asked this once before but which lengths of steering arm and upper-arm turnbuckles do I need?
I dont mind looking it up in one of the manuals but I dont know which rc10's had them... or even if the manual gives the right lengths for the threaded rod.
Also, are the turnbuckle tools available and where?
-Peter
-Peter
- Has thanked: 727 times
- Been thanked: 26 times
I hope this helps,
Turnbuckles from RC10 Worlds Manual using Associated ballcups.
6263 x 2 Steering 2.06"/52.32mm
6260 x 2 Steering Rack 1.00"/25.4mm
6264 x 2 Rear Camber 1.375"/34.925mm
6262 x 2 Front Camber 1.65"/41.91mm
Cheers, Dave
Cheers, Dave
very helpful...
now another question: when i look at the rc10 worlds build manual, it lists a part number 6207 for the front arm mounts. but when i look at tower hobbies otherwise pretty comprehensive list of parts, it does not have the 6207. but amazon does. what gives? should i use the 6207 for a simple conversion to long arm? or is that part number superseded by a number that tower hobbies does have on it's parts list?
or should i be shopping somewhere else? it's just that i already have an account there for my rc airplane stuff. always happy to give my business to guys recommended by the forums, when possible.
-peter
-peter
- vintage AE
- Has thanked: 29 times
- Been thanked: 36 times
I'm glad to find this thread. I was about to double check all this stuff.
I just checked the Worlds Manual and my old RC10 manual.
Part number 6208 RC10 Front Arm Mounts (Left and Right) (White) old part number 6207.
Part number 6207 RC10 Front Arm Mounts (Left and Right) (Black).
Both in stock at Tower Hobbies.
Cheers, Dave.
Cheers, Dave.
- GodSpeed
I'm asking seriously, not condescendingly, why would someone need to order arm mounts (6208) to convert to wide arms? They're already on the car, right? Or do you NEED the 6207 ones?
Also, are there white long arms available?
- uniquenamehere
Unfortunately not... but you can always find them used on eBay...GodSpeed wrote:Also, are there white long arms available?
In my case, it was complete and utter ignorance. I didn't know if the mounts for wide arms were the same or different than the narrow ones. And it didn't help that the part number shown in the manual for a wide arm buggy is different than the one shown in manual for the narrow buggy. Thats why it takes someone who knows what hes doing to point out the difference.GodSpeed wrote:I'm asking seriously, not condescendingly, why would someone need to order arm mounts (6208) to convert to wide arms? They're already on the car, right? Or do you NEED the 6207 ones?
Since I'm not interested in collectibility or authenticity, I don't care about color.
-Peter
- 3745 Views
Last post by pcrussell50
- 1198 Views
Last post by michiganionia
- 804 Views
Last post by badhoopty
- 385 Views
Last post by klavy69
- 1168 Views
Last post by RCveteran
- 1174 Views
Last post by bscotti
- 1074 Views
Last post by TheSpeedway
- 987 Views
