Wheelbase difference between RPM rear arms and AE arms
The later AE arms for the 10T, GT and T2 have the spacer for adjusting the wheelbase. The early AE white arms and the RPM arms dont. My question is lined up next to each other is Does the RPM arms line up with the short or long position or are they in the middle? Thanks
Nick
Nick
- Charlie don't surf
- Has thanked: 355 times
- Been thanked: 470 times
Re: Wheelbase difference between RPM rear arms and AE arms
What spacer are you referring to? the fore/aft space on the hub side? If so, then it is the same overall as the standard rc10 or 10t wheelbase, because you used to adjust via the toe blocks- the same adjustment is now on the hub side, in smaller increments-
The spacer on the outer hingepin is what I am refering to. I know it doesent change toe, just the wheelbase. What im asking is, if I went from the rpm arms to the ae arms, would the front or rear position be the same as the rpm arm as far as wheelbase goes.
Kinda related, is there any rear arm mounts available other than ebay? I was thinking every number I could find was discontinued through tower.
Nck
Nck
The RPM arm position would be dead center of the "adjustment" of the AE arm- and other than the BST here, and ebay that's it really for the blockscautrell05 wrote:The spacer on the outer hingepin is what I am refering to. I know it doesent change toe, just the wheelbase. What im asking is, if I went from the rpm arms to the ae arms, would the front or rear position be the same as the rpm arm as far as wheelbase goes.
Nck
Thanks. that was what I was looking for.
Nick
Nick
- 967 Views
Last post by BattleTrak
- 672 Views
Last post by cochecito
- 1492 Views
Last post by Twistedaxle
- 805 Views
Last post by mikedealer
- 575 Views
Last post by Lonestar
- 1634 Views
Last post by Badmuthatrucker
- 2616 Views
Last post by jcwrks
- 588 Views
Last post by Dr. Robotnik
Users browsing this forum: Bing [Bot],
Seznam [Bot] and 5 guests
