Cougar wheels in acetone??
- Has thanked: 25 times
- Been thanked: 29 times
Hi Guys, sorry if it's been asked before but is ok to put Cougar 1/2 wheels in acetone to remove the old Tyres??
Also any tips on removing paint from the wheels??
One set could do with being a bit whiter, can I bleach the wheels? Or any other ways to get them bright White again??
If in doubt go flat out!
Re: Cougar wheels in acetone??
I'm fairly certain that the Cougar wheels are fine in acetone. Seems like I did some a couple of years ago. Might be best to try it out on an out of sight spot with a drop or two (inner rim maybe?) As far as paint goes, there are a nuber of ways to remove it. If the acetone doesn't take it off, Easy Off oven cleaner in the yellow can, brake fluid, or Super Clean (Purple automotive degreaser) will also work.
Gary
In addition to what Redscampi said, if you are in the UK then Fairy Power Spray is similar to the US Easy oven off.Headling wrote:Also any tips on removing paint from the wheels??
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
If it's either the 2.0" Topcat/Cougar/Procat rims then you wont have any problems. Even the 2.2" Aerodiscs seem to cope well enough with the acetone.
- 611 Views
Last post by jaro
- 22 Replies
- 2402 Views
Last post by bearrickster
- 801 Views
Last post by DerbyDan
- 1227 Views
Last post by 8rad
- 570 Views
Last post by rctenracer
- 726 Views
- 937 Views
Last post by Dr. Robotnik
- 955 Views
Last post by flustorm99
