acetone ?
- Been thanked: 81 times
acetone ?
I have a set of b3 sport rims that I want to use on another project. I have heard that acetone will break down the glue. What about the acetone effecting the rims I think they are nylon . Im not looking to save the tires just the rims.
- mikedealer
Re: accetone ?
i have had luck in keeping my rims outside (like in 0-10degree weather) and the cold makes the glue or rubber fragile where it will break right off with quick snaps.
as far as the acetone, i wouldnt recommended it. that stuff, if you drop like a craftsmen screwdriver into it, it will melt the plastic into a pool of liquid plastic mess.
- ROH73
- Been thanked: 23 times
Re: acetone ?
I've had great results with acetone on nylon rims. If they are stock associated, your B3 rims should be nylon, but proceed at your own risk. ABS, polystyrene, polycarbonate, etc. and acetone don't mix.
I usually cut the tire off with an x-acto knife and then soak the rims until the CA glue dissolves. It doesn't take long. Be sure to have a cover for the container the rims are soaking in; acetone evaporates very quickly.
Regards,
Robert
Regards,
Robert
- bearrickster
Re: acetone ?
I have done a 100 rims with acetone, I just put it in a plastic butter tub or icecream tub, just plastic with a lid. then pack it as full as it will go with tires and still be able to close the lid. pour in the acetone close it up then let them soak. they must be sealed. then when their ready seperate the wheels and tires, I then soak the rims in Castrol Super Clean in the same manner. the rims will come out of the super clean I keep all of my old tooth brushes for parts give them a little scrub, they look like new.
- Brandon G
Re: acetone ?
I got an empty 1 gallon paint can from lowe's for my acetone bath. Does a great job of keeping it and the fumes where they belong. Works great on most reputable wheels. (Duratrax need not apply) Careful with Tamiya too.
- Has thanked: 7 times
- Been thanked: 42 times
Re: acetone ?
Juts to add, the wheels don't need to be submerged in the acetone, the fumes do the majority of the work. Pour an inch or two into the bottom and put something in there (brick or whatever) to set the wheels on and watch the tires fall off the next day. I like the idea about using the Castrol Superclean
Re: acetone ?
I like your idea I will give it a try and keep my fingres crossed .
adam lancia wrote:Juts to add, the wheels don't need to be submerged in the acetone, the fumes do the majority of the work. Pour an inch or two into the bottom and put something in there (brick or whatever) to set the wheels on and watch the tires fall off the next day. I like the idea about using the Castrol Superclean
- 568 Views
Last post by rctenracer
- 935 Views
Last post by Dr. Robotnik
- 1910 Views
Last post by Jay Dub
- 948 Views
Last post by flustorm99
- 1499 Views
Last post by Bormac
- 610 Views
Last post by jaro
- 2367 Views
- 22 Replies
- 2377 Views
Last post by bearrickster
