Acetone - IT WORKS!
mrlexan
Acetone - IT WORKS!
Post by mrlexan »
Just wanted to share with everyone and not that I doubted any of you, but Acetone does work to remove epoxy from graphite chassis plates. I had three Losi JRX2 chassis plates that now look as good as new after a bath in Acetone (I should have taken photos). There was one with a huge glob of what looked like JB weld (I am sure it wasn't) that was over a 0.25 inch thick............ GONE!
www.gojammedia.com
Brandon G
Re: Acetone - IT WORKS!
Post by Brandon G »
Should work on superglue too then?
carloco8
Has thanked: 74 times
Been thanked: 271 times
Post by carloco8 »
bngiles wrote:Should work on superglue too then?
Yup!
Dr. Robotnik
Post by Dr. Robotnik »
I have to say Acetone is the best cleaner I have found. So good for used wheels! Not good for ABS plastic though.
RETRO R/C
Has thanked: 11 times
Post by RETRO R/C »
Just be careful that the chassis does not start to de-laminte.......as I have had this happen.
Acetone is awesome - but particularly nasty.
Cheers
Darryn
TO KNOW WHERE YOU ARE GOING - YOU HAVE TO KNOW WHERE YOU HAVE BEEN
VENOM International | Factory Pilot - Team SCHUMACHER UK | J-Concepts USA | B-Fast Performance USA | Bugle Boy Racing | MAX Racing Products International
Dr. Robotnik
RETRO R/C wrote:Just be careful that the chassis does not start to de-laminte.......as I have had this happen.
Cheers
Darryn
Yes don't use it willy nilly on fibreglass as it can de-laminate as the acetone eats the resin/glue which holds them together. You can use it on fibreglass but you have to be very careful you are wiping off what you want, e.g. glue or paint or something and not the resin holding it all together...for fibreglass don't soak it just wipe it on and then off again...
It's fine for graphite and carbon fibre though...just go softly.
It's rank and nasty but I love the stuff...
mrlexan
Post by mrlexan »
Dr. Robotnik wrote: I love the stuff...
Things are starting to make sense know. :lol: :lol:
www.gojammedia.com
Dr. Robotnik
Who doesn't love a nice pint of Acetone, of an evening. It sure helps me unwind :D
