Overnight they completely broke down into a pile goo.
Hello Erik,Mr. ED wrote:On a similar line: don't run grasshopper or frog rims. They're made of ABS (I think) instead of nylon.
Afer about 5 packs off-road I discovered today the walls around the front bearings have cracked![]()
Pretty disappointing as the concept will loose all its charme with modern wheels.
Anybody know of better rims to take the good-as-new tires
I don't put them in the oven. I get an old pot, fill it with water, drop the wheels/tires in and put it on top of the stove and let it boil. Of course some of the goo gets left on the wheel, but most of the sticky stuff usually breaks down pretty good and you can scrape whatever is left off with an xacto knife. I've never done it with really old tires, but I've done it with Clod tires and newer buggy tires without any damage to the tires or the wheel.mrlexan wrote:That doesn't work as well as the Acetone....... some are good and some are bad, usually takes two or three bouts in the oven for that to work and you don't get all the rubber off the wheels. Schumacher tires specifically break down in the oven. You put them in, try to muscle them off and it just tears like paper. The acetone works the best, the eco-friendly guy in me does really like it too much.
Thanks for the tip roger,highwayracer wrote:
Hello Erik,
Look for the 1 piece panda wheels...they come in white or yellow. The wheels are also ABS, but much more durable since there's more material.
