Stealth gearbox rebuild questions
- Rizzo
G'day guys
I have recently rebuilt my stealth gearbox & I have a problem. No matter how much I tighten the torque control nut I can'r get drive to the wheels (it just spins) & it seems as though something in the actual gearbox is spinning.
I also adjusted the diff thrust spring as per the manual but think I have done something wrong as the diff is really tight & if I hold onto the left rear wheel & turn the right one anti clockwise, sometimes I can actually undo the diff thrust spring.
Can u guys think of any amatuer errors which I could have done, or what i could have overlooked in the rebuild?
regards
jak
regards
jak
"Don't underestimate the power of a backhander. They F&^%ing hurt" SuperWog
- mikedealer
Re: Stealth gearbox rebuild questions
are u missing the pin on the top shaft behind the rear slipper plate?
- Rizzo
Thanks, I checked that, it's definalty there.
The car will move under power, just there is something spinning like crazy in the box? it does get the car going though, albeit slowly
Jak
Jak
- Has thanked: 36 times
- Been thanked: 1318 times
did you rebuild it with new diff parts (bolt, nut, spring, thrust bearings)?
- mikedealer
ya that would be my next guess..
if you take 2 small allen wrenches and lock both outdrives, you should be able to easily move the diff gear at all.
i cant think of anything else.
- Rizzo
Yes, I just put those in this morning as they just arrived from tower hobbiesscr8p wrote:did you rebuild it with new diff parts (bolt, nut, spring, thrust bearings)?
Jak
seems like there's an issue with the thrust balls and washers if the diff loosens spinning the right outdrive counter clockwise.
- Rizzo
I'm a stooge.
I just quickly pulled it apart again & I had both washers that are supposed to go either side of the diff & balls stuck together on 1 side.
I'll try it again & see if thats it
jak
jak
i'm not exactly sure what you mean by...... either side of the diff and balls. the 6 thrust balls get sandwiched between the 2 washers in the right outdrive.Rizzo wrote:I'm a stooge.
jak
it's late, and i'm tired. the way i'm taking what your saying is you're gonna put one of the washers in the left outdrive. if so, don't do that.
- Rizzo
Sorry, may have said it wrong, I have the 6 balls in between the 2 washers on the right outdrive, I mean inside the gearbox, there are 2 large diff drive rings that are supposed to go either side of the main diff gear, I had both of these on 1 side.
In my haste I stuffed it up
, wel I hope thats it
Jak
Jak
- Rizzo
SORTED!!!
Thank u very much for all the replies.
now she is all ready for the next vintage meet!
regards
Jak
regards
Jak
- 1379 Views
Last post by adam lancia
- 898 Views
Last post by 4.whoa
- 26 Replies
- 2805 Views
Last post by SnoopMaxx
- 2089 Views
Last post by dinglem
- 1569 Views
Last post by jeepy2013
- 1838 Views
Last post by drbelleville
- 1306 Views
Last post by Asso_man!
- 666 Views
Last post by juicedcoupe
Users browsing this forum: Tbot [Bot] and 3 guests
