My ReBuild Questions Thread
General info, Q&A.
MONSTER
Post by MONSTER »
How many different Degree Block Carriers are there? I have 2 diff sets.
Give me some simple explainations of the effects each have on car.
Left = Drivers Side, correct? As if Sitting In the car.
MONSTER
Re: My ReBuild Questions Thread
Post by MONSTER »
I have 3 different White Bulkheads. What car does each go with?
1. 9 TB Holes, Short Wing Tube Holes
2. 9 TB Holes, Long Wing Tube Holes
3. 4 TB Holes, Short Wing Tube Holes
there's 2 different hub carriers. 0 and 1.5 degree. the "L" means left, as in driver side, which would be a 1.5.
MONSTER
Post by MONSTER »
scr8p wrote:there's 2 different hub carriers. 0 and 1.5 degree. the "L" means left, as in driver side, which would be a 1.5.
I dont get that part. A different degree for each side?
badhoopty
Has thanked: 183 times
Been thanked: 157 times
Post by badhoopty »
no, each side should have the same 0 or 1.5 degree carrier.
MONSTER
Post by MONSTER »
badhoopty wrote:no, each side should have the same 0 or 1.5 degree carrier.
What are the Pros and Cons of each?
badhoopty
Post by badhoopty »
toe in at the rear increases traction at the expense of top speed and turn-in.
i think...
MONSTER
Post by MONSTER »
Wait, Im talking about FRONT Block Carriers, not REAR Hub Carriers. I should have been more specific, my bad.
in that case, there's 6. 5, 10, 15, 20, 25, and 30 degree castor blocks. here's a guide to understanding suspension setup. go to "suspension geometry" in the table of contents.
http://aedownloads.com/pdf/RC_HandbookV2.pdf
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
1. 9 TB Holes, Short Wing Tube Holes: Team Car and CE edition with Stealth and white parts
2. 9 TB Holes, Long Wing Tube Holes: first gen. early cars (stock gold tub and early CE edition)
3. 4 TB Holes, Short Wing Tube Holes: World's car and (maybe) last production runs for the CE edition, latest version
Come and visit the stable
templeofspeed
Been thanked: 33 times
Post by templeofspeed »
Asso_man! wrote:1. 9 TB Holes, Short Wing Tube Holes: Team Car and CE edition with Stealth and white parts
#2 early gold tub and early TQ10. The CE had short wing tubes because of the longer rear camber link, as started on the graphite car.
Asso_man!
Post by Asso_man! »
yeah, I wasn't too sure about that one policeman :P
highwayracer
Been thanked: 6 times
Post by highwayracer »
For the front castor blocks, there were 5.
6211 5 degrees
6212 10 degrees
6213 15 degrees (standard)
6214 20 degrees
6215 25 degrees
This was from an older catalog, so Associated may have come up with more.
Changing the castor block changed the pivot angle of the front wheel with respect to the ground. Using a truck wheel (because it's wider) as an example, a 5 degree block will always allow the full contact patch of the tire to stay flat with the ground. Changing it to a 25 degree block, you will notice that the contact patch is only flat when the truck is going straignt. When the tires are turned, only the edges of the tires will be touching the ground.
Changing the block to a 5 degree may sound like a good idea, but the car becomes more "twitchy"...less forgiving. Generally, my off road trucks would have 25 degree blocks while my on road (carpet) trucks would only have 10 degree blocks.
hope this helps...
regards,
highwayracer
regards,
highwayracer
MONSTER
Post by MONSTER »
Thanks for all the info, Guys. Like I said, out of the 5 Sets I have, 4 are nearly straight up and down (to the ground), and 1 is maybe the 20*/25*. I dont see any marking to indicate what degree they may be. The Degree is measured in relation to the ground, correct?
I decided to put the "angled set" on the Short Arm Car, and a "straight up set" on the Wide Arm Car. What would you guys do, given the parts options on hand?
Progress Pics Tomorrow!!
aconsola
Post by aconsola »
MONSTER wrote:The Degree is measured in relation to the ground, correct?
The angle is the relation of the kingpin compared to a line perpendicular to the ground. The 30 degree blocks are actually square, the kingpin and hinge pin are 90degree from each other. this is because the nose of the chassis has 30 degrees of caster built in. The 0degree blocks have the most angle to them with the hinge pin and king pin at 60degrees (measured on forward side) this will remove the 30 degrees introduced by the chassis and put the kingpin at 90 degrees to the ground.
