MIP Gearbox rebuild help....
Hi everyone,
I got a MIP gearbox in a box of bits from Felabay a while ago and I'm wanting to use it on the "plank".
Last night I stripped it and amazed all metal gears, plus ball diff, BONUS!!
Never knew anything about these before hand.
Anyway, black as the ace of spades on the inside, got it all stripped, cleaned, ball bearings and all!
Really, really smooth now, it actually spins......
Problem is, I don't know how to open the diff.....
I tried the smallest allen key I have and that didn't fit, the holes so small I can't see what I actually need to open the dam thing up!
Any ideas, I've searched and found nothing, found some docs and reviews on how good it is, plus a few people using them, but no rebuild info.
It's the same box as this one: http://www.rc10talk.com/viewtopic.php?f=35&t=15210
Can anyone help??
Can anyone help??
- bscotti
Re: MIP Gearbox rebuild help....
Super thanks, just what I needed, can't read it so I've PM'd him, thanks!!!
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Did you click on the pictures to enlarge them? I doubt you'll get a response from him he's kind of been persona non grata around here for quite a while.
This is all very interesting!
Yeah, downloaded them and zoomed in, it's defo a hex key of some sort....
- Has thanked: 7 times
- Been thanked: 42 times
2mm also works, the 2 sizes are within a few thou's of each other.aeiou wrote:5/64
2mm?? Not got it in front of me, but that seems far too big for the diff screw?adam lancia wrote:2mm also works, the 2 sizes are within a few thou's of each other.aeiou wrote:5/64
I've got 1.5mm for pinions and that won't fit it.....
Got a 5/64 on order, so fingers crossed!!
You have taken those 3 small screws out and removed that outer (stub) already right? If not, a 2mm or 5/64 L-shaped allen key will be the only thing that will fit through that tiny hole in the (stub). The only other size I can think of that it *might might* be is .050, but that's way too small for a differential bolt, unless the head is a weird one-off tiny hex. I highly doubt that though. Post a couple of pictures, that'll help.
- 1115 Views
Last post by RCveteran
- 686 Views
Last post by ThomasH
- 1528 Views
Last post by Rizzo
- 3491 Views
Last post by limestang
- 514 Views
- 1574 Views
Last post by Asso_man!
- 802 Views
Last post by HS-YZ250
- 19 Replies
- 2498 Views
Last post by R Cane
