If there is a topic already, please point me in the right direction, and then the mods can delete this.
Thanks,
Maurice
I was thinking that with the newer more powerful Brushless motors and 2.2 tires, it would seem like a logical choice. And a better bottom end is always a good thing as well.Charlie don't surf wrote:Well, the gear ratio is different as a result of the topshaft as well, the 2.65 internal ratio of the RPM tranny also is a little quicker to spool, keeping the temps down. But I have run both with a 6.5 on a super bite track and other than the spur/pinion ratio they both work well ( I prefer the RPM ) the B4 slipper is easier to adapt to the 2.25 stealth ( top shaft/plates pads/spring & nut )
and is the only weak spot in the 2.25 or the RPM with the stock slipper-
precisely the reason there's a 1.96 rpm trans in my v-nats car (17.5).adam lancia wrote:As it is already, guys running 17.5's in B4's are running 68 tooth spurs and 38 tooth pinions to get a decent gear ratio as the motors love to pull tons of gear.
