RPM 2.65 stealth conversion on buggy?
General info, Q&A.
AYKBOBCAT
Post by AYKBOBCAT »
I got one of those with a set of parts... It's supposed to be made for the RC10T but whay not on a buggy?
What's the effect? Much punch but less top end speed?
Eau Rouge
Post by Eau Rouge »
On a buggy, they just took different gearing to get right for the tire size. They were popular on dirt ovals for short tracks, though.
yup, more or less. you can use it in a buggy, just use a smaller spur gear.
carloco8
Has thanked: 74 times
Been thanked: 271 times
Post by carloco8 »
Put it in whatever rc10 you want, truck or buggy, followed by a 9 turn motor with ease :D . Good for short tracks like apexspeed said. The high speed dirt oval guys had the RPM 1.9 ratio stealth trans with the dark grey case too. Definitely harder to find now.
Eau Rouge
Re: RPM 2.65 stealth conversion on buggy?
Post by Eau Rouge »
AYKBOBCAT wrote:What's the effect? Much punch but less top end speed?
Yeah, essentially, the tall drive ratio was to counteract the truck tires and get the same gear ratio as a buggy. The result, if geared the way it is supposed to be geared, is no different that a 2.0 gearbox.
The DO guys liked it because you could run really hot motors on short tracks and not worry about problematic gearing.
ah yes, d.o. short tracks. those were the days. there isn't many around anymore since the nitro invasion. in my area anyway.
