RC10GT T2 Stealth Transmission fitment?
- RCveteran
- Has thanked: 25 times
- Been thanked: 183 times
I picked one of these up off ebay with the intent of putting it on my buggy, but it appears different than the regular stealth, it is layed down like? Are the internals the same and can they be swapped?
What did I get here?
- Been thanked: 4 times
Re: RC10GT T2 Stealth Transmission fitment?
Either the gt AND t2 suspension parts work and front tower,tierods bearings slippers but trannys no.bolt up patterns are different.Don
- Been thanked: 498 times
the gt trans uses a layed down arrangement due to the nitro engine. Someone here built a sweet mid motor car using that trans and a custom motor mount. I tried to find it the other day but wasn't having much luck.....
- RCveteran
Learn something new everyday. I wonder are the internals the same, so if I had a regular stealth case I could swap?
Though a custom mid engine sounds cool to.
i think the internal dif is alot larger than the regular stealth i though about doing the same and the internals are way bigger
Paul
Paul
- Has thanked: 7 times
- Been thanked: 42 times
The GT diff is the large B2/T2 sized diff, not compatible with the original Stealth casing. The top shaft, slipper and bearings will swap over though.
- klavy69
- Moderator
- Has thanked: 628 times
- Been thanked: 294 times
I believe you are right. I think it was Ford...drawing a blank right now even though I've bought a ton of stuff from him. Would've been in this part of the forum within the last 6 months...damn it I hate when I have a name just outta my graspjwscab wrote:actually, the one I was thinking of was an oval truck I think......
AHA...PBR Allstar (Ford) is the one that did that custom oval with the gt tranny that I'm thinkin of. Its on page 5 of the 'Spring RC10Talk RC10T Competition!' thread in this part of the forum...I can't seem to search it then put the link in here...keeps showin up as the search even though its on the thread.
yeah, i know...it probably was Ford, but searching I just can't find it.....I hate when that happens....
going from your tip, it WAS Ford:
http://www.rc10talk.com/viewtopic.php?f=36&t=12643
nice!!! thanks!!!
nice!!! thanks!!!
- klavy69
- Moderator
This is another one of his:
http://www.rc10talk.com/viewtopic.php?f=36&t=14518&start=60
bout half way down the page is his but I can't remember if that one had a gt tranny in it or not
- 1129 Views
Last post by Basher67
- 994 Views
Last post by Joe6Pack74
- 1241 Views
Last post by Texas_Man2011
- 1051 Views
Last post by KidAgain
- 2661 Views
Last post by n20capri
- 2498 Views
Last post by Phin
- 3656 Views
- 22 Replies
- 4538 Views
Last post by Chemical
