Stealth Transmission
Is there other associated truck tranny parts that will work/replace the #6585 clutch disk, #6584 outer hub and #6583 clutch hub for the stealth tranny? Anyone even have these replacement parts?
- Has thanked: 36 times
- Been thanked: 1318 times
Re: Stealth Transmission
the b2/b3/t3 slipper stuff will work. or you can replace the topshaft in the trans with one for a b4/t4 and use the b4/t4 slipper setup on it.
I have all the parts except those mentioned above. Do you know what the crossover part numbers would be? It has been 20 years since I have rebuilt one of these and I have a few that I want to rebuild. Not as easy as I remember.
scr8p wrote:the b2/b3/t3 slipper stuff will work. or you can replace the topshaft in the trans with one for a b4/t4 and use the b4/t4 slipper setup on it.
Was wondering if you can point me to direction to find hydra drive conversion for RC10T?
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
The hydra setup is the same between the rc10 & 10t, and they are not the most common parts to find, ebay is the easiest-
You just need to find a top shaft for hydra and your set, im sure if you post it in the wanted section guys here will hep you out,did the same here Nd was able to get both for stealth and rpm conversion tranny.
― Confucius
― Confucius
Old thread I know but I just got the 9253 slipper clutch for my RC10T stealth refurb (to replace the original 6585 disk) and it's too big. Do I now need the 9251 inner hub and the 9252 outer hub? Also will my current hub bearing work with the new hub? It looks like the shaft is the same - just trying to figure out what I need...
Thanks
Thanks
-Mike
RC10T | Kyosho Lazer ZX - 55mph | Mid Motor RC10 Pan Car Conversion - 72mph | OIN RC10 spare/used parts build - 69mph | 4x4 MonsterT build
86 ascMcLaren Capri 5.0 | 86 Mustang SVO
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
- Has thanked: 1129 times
- Been thanked: 3919 times
Yes on the t3 plates and your shaft is fine. You need a 3/16 x 3/8 bushing for that slipper assy. Same as front wheel bushings.
I saw the bushing part# in the manual...is there a bearing that will work? Or has to be bushing?gomachv wrote:Yes on the t3 plates and your shaft is fine. You need a 3/16 x 3/8 bushing for that slipper assy. Same as front wheel bushings.
Thanks!
-Mike
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
And will I need a new spur gear too?? Ughhh lol
-Mike
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
Great thanks we'll see if this works! lol. Nearing $50 between this and the diff...should have just got a new stealth! ha
-Mike
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
I believe when I first started looking they were all sold. I thought the newer one was a replacement...no biggy I always like upgrades! lol
-Mike
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
- 1268 Views
Last post by Texas_Man2011
- 2540 Views
Last post by Phin
- 1073 Views
Last post by KidAgain
- 586 Views
Last post by bigtenuk
- 1007 Views
Last post by mAdMan
- 3718 Views
- 1107 Views
Last post by Erich Reichert
- 22 Replies
- 4694 Views
Last post by Chemical
