Stealth Transmission questions
- esaresky75
Trying to learn about the stealth transmission. So reading the sticky "25 years of RC10", am I correct the stealth came in white and black plastic? If so, how do you tell a non-stealth from a stealth? What make the stealth special? I can ask a few more questions but will wait in case there is already a thread on the subject.
Thanks
Thanks
Burn more coal - UnderGroundMiners.com
- Johnboy72
Re: Stealth Transmission questions
Well the original RC10 had a 6 gear transmission. It's blocky looking. All the Stealth transmissions had 3 gears. If I'm not mistaken, the early models were white. The ratios changed thru the years and models. You'd have to do a search to find out which is which. I have a three or four laying around and while they're all black, they each are different.
original production Stealths were white.
"Almost Live Race Coverage": http://www.johnnyboy.ca
.:Kyosho America : Peak Racing : JConcepts : JTP : Darkside Designs:.
- esaresky75
I was doing more research. I found this info, is it correct?
Original stealth ratio 2.25:1
B3 Stealth 2.4:1
B4 Stealth 2.6:1
6 gear 1.83:1
B3 Stealth 2.4:1
B4 Stealth 2.6:1
6 gear 1.83:1
- losiXXXman
- Been thanked: 5 times
Those are correct. Also, the B3/T3 share trannies. Don't forget the T2 which had a 2.6 also. Several guys here have built buggies based on the T2 chassis as well, just shortening the nose plate for a buggy wheelbase (and the obvious suspension/wheel/tire change). AND there's the RPM change boxes for stealth. One had a 1.96 and the other had a 2.65. The 2.65 is still available, but not the 1.96. (unfortuantely.) There's lots of other trannies too, but I won;t get in to that.
you're in luck....this question was just asked:
http://www.rc10talk.com/viewtopic.php?f=38&t=19498&hilit=stealth+ratio
- 2695 Views
Last post by n20capri
- 1268 Views
Last post by Texas_Man2011
- 2541 Views
Last post by Phin
- 1073 Views
Last post by KidAgain
- 23 Replies
- 3429 Views
Last post by SteveK
- 1245 Views
Last post by mc10ce
- 2926 Views
Last post by askbob
- 1107 Views
Last post by Erich Reichert
Users browsing this forum: Amazon [Bot] and 4 guests
