Stealth Transmission à la carte
Chemical
Been thanked: 6 times
Post by Chemical »
With new Stealth Transmission kits unavailable, I created a "wish list" online at A-Main hobbies of all the individual parts to build one.
Adding up the nickels and dimes, the grand total would be $167 USD. Only one part is missing (left out-drive).
Partial screen shot:
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Re: Stealth Transmission à la carte
Post by XLR8 »
Do you think if, as a group effort, we flooded AE and every other AE parts source worldwide with requests for the left out-drive that it might trigger AE's inventory management system to place new production orders for that part with their suppliers? We should do that and see what happens. :mrgreen:
bluewormx
Has thanked: 41 times
Been thanked: 91 times
Post by bluewormx »
Chemical wrote: Sat Sep 08, 2018 8:46 pm With new Stealth Transmission kits unavailable, I created a "wish list" online at A-Main hobbies of all the individual parts to build one.
From the picture I can see you have used 6564 transmission. Don't the gear mesh is screwed up and has incorrect backlash.
Use 6565 transmission case and 6570 idler gear. :D
WOW $167!!! it can be done for less.
mikea96
Has thanked: 659 times
Been thanked: 878 times
Post by mikea96 »
NomadRacer
Has thanked: 81 times
Been thanked: 79 times
Post by NomadRacer »
Yep, can be done for around 100 bucks, or less. Biggest thing is the outdrives.
Bum on Direct Deposit
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Post by mk-Zero »
NomadRacer wrote: Sun Sep 09, 2018 11:22 am Yep, can be done for around 100 bucks, or less. Biggest thing is the outdrives.
I know where you can get a pair in beautiful aluminum for $32 + shipping! :mrgreen:
discgolfer72
Has thanked: 21 times
Been thanked: 36 times
Post by discgolfer72 »
wanted to build a new stealth for my latest build
and have every part needed new in package in my bins except for the outdrives , so I just had to order a beater from ebay and hope for the best
NomadRacer
discgolfer72 wrote: Mon Sep 10, 2018 12:05 pm
You can get this...
https://www.rc10talk.com/viewtopic.php?f=6&t=43231
:mrgreen:
DPowell
Post by DPowell »
Needing a Stealth transmission also.
Would an AE SC10 9853 ball diff kit be a possible solution for hard to find out drives?
Thanks,
rctenracer
Been thanked: 81 times
Post by rctenracer »
DPowell wrote: Wed Sep 12, 2018 10:59 pm Needing a Stealth transmission also.
Thanks,
Those out drives aren't compatible with the RC10 stealth trans . The SC10 is based on the B4 platform .
XLR8
Post by XLR8 »
Correct. The SC10 (B4) tranny is 2.6:1 ratio (52t diff gear) while the Stealth is 2.25:1 ratio (45t diff gear). So, the obstacle to using SC10 out-drives in a Stealth is a difference in ring diameters (bone interface and bearings are the same).
SC10 uses ring #7666 (fits 52t gear) while Stealth uses ring #6579 (fits a 45t gear). So the SC10 out-drives require a ring that is too large to fit the Stealth's gear.
Maybe someone could design and print a special Stealth case that will accept an SC10 diff assembly.
I have turned a set of b4 outdrives down to the smaller ring size. You have to turn the od down, and trim back the lip/flange so the 2.25 ring fits.
It's hard material so it's hard on the lathe and tooling, for a large machine, it's no big deal. For you taig guys, I don't thing it will do it. I used an old atlas 6" lathe and it was NOT happy.
I suppose you could also mount a die grinder in your toolpost and grind it down also. Tend to get grit in your lathe however.
NomadRacer
jwscab wrote: Thu Sep 13, 2018 7:49 am I have turned a set of b4 outdrives down to the smaller ring size. You have to turn the od down, and trim back the lip/flange so the 2.25 ring fits.
I'd not try it with a Micro Lathe like the Taig. I got onto hardened tool steel with a Carbide bit and it destroyed the bit, ruined the part and the belt (lathe drive) was smoked. Cost me some bucks. :(
XLR8
Post by XLR8 »
Awesome! I've always thought that might be possible, just been waiting for someone to tell us they've done it. So, as the supply of Stealth out-drives dry up, there are options besides just parking our cars.
there is a crappy picture of them in this thread:
https://www.rc10talk.com/viewtopic.php?f=35&t=21295&hilit=outdrive+machined&start=300
yeah, the problem is all of the new stuff is going to a metric outdrive bearing, and as B4/T4 starts to dry up, they will be hard to find. SO if you are planning to try it, get a couple sets while still around.
a printed stealth case that fits the metric bearing and gear diff/ball diff of the newer cars would be cool.
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarDotNetDotCom.org [Bot], No User AvatarYandex [Bot] and 6 guests
