stealth transmission
so if there is a B stamped on the inside of the backend of the pan does that mean that i have the stealth transmission
RC10L: ALL ORIGINAL
OFNA LX2 NITRO BB .28 ENGINE
ECX CIRCUIT: 130A ESC AND A 6000KV MOTOR
- Has thanked: 36 times
- Been thanked: 1318 times
Re: stealth transmission
it means your chassis is drilled for one. it doesn't necessarily mean that's the trans you have (without seeing pics)......
RC10L: ALL ORIGINAL
What is the best gear lube to put in this, I don't want to kill it even though I have another one in the parts truck that i am using
RC10L: ALL ORIGINAL
No lube on the gears, just in the diff. The idler and diff gear are nylon/delrin; they don't need lubrication, and it just becomes a dust magnet (which actually will damage the gears)
+1 thanks guys. im just still trying to figure out what other parts are interchangeable with the rc10T. just in case if I need anything
RC10L: ALL ORIGINAL
- 2693 Views
Last post by n20capri
- 2539 Views
Last post by Phin
- 1072 Views
Last post by KidAgain
- 583 Views
Last post by bigtenuk
- 1006 Views
Last post by mAdMan
- 3716 Views
- 1106 Views
Last post by Erich Reichert
- 22 Replies
- 4687 Views
Last post by Chemical
