cvd bearings and 2.2 wheels
Hi all
What size bearings do I need to run CVDs please?
Also I have had a search around the forums and it seems that the duratrax wheels are the only 2.2 available now is this correct?
Thanks
Thanks
Still building my RC10
- Brandon G
Re: cvd bearings and 2.2 wheels
http://www.rc10talk.com/viewtopic.php?f=38&t=9253&p=88751&hilit=kyosho+wheel#p88751
What rear hubs and axles are you trying to use?
Well I just bought some MIPs from tower and the hubs are the original ones.
- Been thanked: 81 times
For the RC10 cvd you will need 4-1/4x3/8 flanged bearings. Check the post in this section " how to run 2.2 tires". I don't think tower stocks the B2 cvd any more Check ebay. Duratrax and kyosho have 2.2 rims that will work with the stock hubs. But those rims will only work with the 3/16 B2 cvd or axles. You can also go this route with associated parts.
2-#7378 axles
1-#7369 pins
1-#7368 shims
4- 3/16x3/8 flanged bearings (from avid)
2-#7378 axles
1-#7369 pins
1-#7368 shims
The CVD axles from the RC10GT will fit any wheels that use 3/16"x3/8" bearings. I'll be doing this when I get around to rebuilding my buggy, in order to run Dirt Hawgs. The other option is to get some dogbones to work with the spare 3/16" axles I have, but I would only save a few dollars versus rebuilding my CVDs.
- 661 Views
Last post by SteveK
- 722 Views
- 679 Views
Last post by RABIDFOX50
- 1850 Views
- 2419 Views
Last post by RC104ever
- 22 Replies
- 3034 Views
Last post by sneako43
- 1987 Views
Last post by Winger
- 4254 Views
Last post by Dual
Mojeek [Bot],
Tbot [Bot] and 5 guests
