I'm converting a ZX-R (well a Mid with ZX-R suspension to be precise) to CVDs and I thought I had everything worked out but I have hit a problem
I have LA231-02 axles and when I assemble them with VZW010 hexes the bearings bind when I tighten up the wheel nuts.
I am using Associated bearings but have also tried other random bearings in my parts bin to no avail
There are no shims anywhere. I am using 3 racing ZX5 knuckles and rear hubs.
I tried an OT-16 knuckle and had the same problem so its not the 3-racing parts
There are two holes for the cross pin on these hubs and I am indeed using the hole which places the drive hub furthest from the bearing so thats not the cause
I have seen one Lazer assembled on Oople with the same parts but that member is not around to comment on any tricks he may have used.
Anyone got any ideas? I'm close to getting this mega-mid on all four wheels so I can then strip and assemble it properly
Do I just need to run the LAW-30 clamp hexes?
What car ran the VZW-010 and what hubs and axles did it use?
CVD Conversion: VZW-010 Drive Washers Binding on Bearings
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
Re: CVD Conversion: VZW-010 Drive Washers Binding on Bearing
VZW is one of the later pureten GP cars (FW-05, 06 or V-One-something).
LAW-30 should work without a hitch. Instead of having a hole they are clamp-style drive washers.
Thanks for the info.
What axles do those GP cars run?
I don't know. I think the manuals can be found on Kyosho Japan's English website though.
- 809 Views
Last post by bully
- 666 Views
Last post by SteveK
- 1103 Views
Last post by SteveK
- 1622 Views
Last post by metallicats33
- 2381 Views
Last post by OMC-Mikey
- 33 Replies
- 4161 Views
Last post by terry.sc
- 791 Views
Last post by dinglem
- 1094 Views
Last post by Headling
