Stealth Transmission à la carte
Re: Stealth Transmission à la carte
Putting the part in a chuck on a rotary table and then using a good carbide end mill might be worth trying.
- Has thanked: 9 times
- Been thanked: 9 times
Thats a good idea! That would definitely make sure runners had steel outdrives readily accessible for years to come.
It seems like 3d printed trans cases (especially those that aren't really structural like the stealth) turn out pretty good 3d printed. I'm not sure if shifting the idler gear to fit a slightly bigger diff gear would be an issue with any trans mounting screws, or if having to raise the diff would make any additional issues for the guys running the kind of short CVA's
for sure there will be tradeoffs. one thing for sure is that the larger gear, if you don't notch the chassis, will ride higher. That will cause some headaches, but nothing insurmountable. at some point, you have to make a line of where the car stops being vintage, and starts being modern.
- Been thanked: 81 times
I have used Custom Works outdrives in the past for the stealth trans . You had to Dremel a very small amount out of the ID on the AE diff rings to fit the CW outdrives if my memory is correct .
http://www.customworksrc.com/cgi-bin/commerce.cgi?add=action&key=4364
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
I agree. The more I think about a special tranny case, the less practical it seems; shifting the idler fore or aft in order to retain the input shaft location, moding the chassis to drop the larger diff gear or maybe special raised hub carriers to match the higher out-drive height, what's next... it just cascades. If AE won't support their product, then eventually market forces will drive entrepreneurs and small manufacturers to develop practical solutions. Glass half full.jwscab wrote: ↑Thu Sep 13, 2018 1:59 pm for sure there will be tradeoffs. one thing for sure is that the larger gear, if you don't notch the chassis, will ride higher. That will cause some headaches, but nothing insurmountable. at some point, you have to make a line of where the car stops being vintage, and starts being modern.
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 21 times
One of these days I'll get back to my printed stainless steel outdrive project. I've been running that pair on my B1M for just over a year now and, although there's some wear, they are holding up great with zero failures. I need to make some dimensional adjustments so they need less post-processing/machining and have another set printed.
https://www.rc10talk.com/viewtopic.php?f=35&t=42028&hilit=outdrive
- 1265 Views
Last post by Texas_Man2011
- 2692 Views
Last post by n20capri
- 2538 Views
Last post by Phin
- 1071 Views
Last post by KidAgain
- 582 Views
Last post by bigtenuk
- 1001 Views
Last post by mAdMan
- 3716 Views
- 1105 Views
Last post by Erich Reichert
