Removing anodizing - another noob question
did a search but couldn't find any posts on this- what's a good method to get a nice clean and complete removal of the original rc10 chassis anodizing?
- PBR Allstar
Re: Removing anodizing - another noob question
I've always used Easy-Off oven cleaner for anno removal, although I've never done a chassis. When you remove the coating though it still requires a little cleanup to make it nice and shiny, you can either polish it, or use some scotch brite for a brushed aluminum look.
- YZ-10
hi mate see this guys guide... http://forums.thetoyz.com/index.php?showtopic=2539
- Has thanked: 183 times
- Been thanked: 157 times
methinks you didnt type in the right search terms...
http://www.rc10talk.com/search.php?keywords=removing+anodizing&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
i know that searching this board is sometimes a huge pita when you are trying to dig up a specific post from a couple years ago, but this issue gets hashed out at least every other month. i dont ever want to be a search nazi, but i can see now how it drives some people crazy...
anyway, easy off in the yellow lid can. i've tried the blue lid stuff and it doesnt work nearly as well and fast.
do NOT let it dry on the surface, i keep everything wet by stripping parts inside a freezer bag so the easy off doesnt dry up. it helps with fumes as well.
it also is nice for inspecting parts and giving them a little shake once in awhile to move the easy off around. it doesnt take long at all, i recently stripped a set of shock bodies with the hard anodizing and it took around 10-15 minutes.
- 809 Views
Last post by badhoopty
- 814 Views
Last post by mtbnjim
- 2201 Views
Last post by Asso_man!
- 305 Views
Last post by BattleTrak
- 953 Views
Last post by Zmd73
- 2323 Views
Last post by Johnboy72
- 553 Views
Last post by Group B
- 982 Views
Last post by slotcarrod
