Removing a kit box label question
- marlo
- Has thanked: 18 times
- Been thanked: 22 times
looking to replacing an ugly box label with a much better one from a donor box. I've tried in the past soaking in water, but failed miserably. Anybody ever tried this before? I'm thinking steam, but since I have only one shot at it, thought I would ask for advice.
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Re: Removing a kit box label question
Only tip I can think of would be to carefully slide a brand new razor under it and try to carefully pull it away as you go. In my mind it seems like this would work better with an ice cold sticker. Steam may loosen up the adhesive, but I'm afraid it would also make the label soggy and very weak. Just a thought. Someone may have a better idea. Good luck.
- LTO_Dave
- Has thanked: 52 times
- Been thanked: 287 times
Wait about 15 years and try again.
I've had the labels on both of my CE boxes fall off after the glue got old from sitting.
I'd stay away from anything using water or steam. Maybe try a heat gun or hair dryer to soften the glue?
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
Steam works for stamps and doesn't make them soggy, IIRC. A heat gun is more likely to damage the paper (either yellow it or burn it) and ink.
How about cutting the donor box in the outline of the label and peel the layer of the box off with the label. It might end up another layer thick but it beats damaging the label.
- marlo
Thanks for the suggestion jwscab, I'll have to look into it. This is not the label I need, but something I tried about a year ago on a scrap box. I cut the box ends off, then soaked them in water... this is NOT the way to do it. Labels became textured like leather, and all around crap!.... Oh well, it was my first attempt, glad it was on these, and not what I was really after.
- THE H.P FREAK
HI!... Scan it and print it. Problem solved.
- slotcarrod
- Been thanked: 45 times
Build a sweat box like we do for high end postage stamps.
http://xes.cx/tag/stamp-sweat-box/
Rod Littau
- 1089 Views
Last post by badhoopty
- 2917 Views
Last post by Alex B
- 3685 Views
Last post by lifeIsAnalog
- 4400 Views
Last post by Toaster
- 646 Views
Last post by a01butal
- 2019 Views
Last post by Jeep-Power
- 654 Views
Last post by THUNDERSTRIKE1
- 796 Views
Last post by jcwrks
