2.25 Stealth or 2.65 RPM?
LTO_Dave
Has thanked: 52 times
Been thanked: 287 times
Post by LTO_Dave »
I'm looking for opinions on which tranny would work best for my re-re World's car this spring. My local track isn't huge and somewhat technical, but I've heard the owner will be making it larger this season. It's a fiarly high-traction track with some bumpy sections. Many of the drivers run green Barcodes and that's what I have ready.
I'm planning to run either a 13.5 or 17.5 brushless combo if money permits. But I might end up using a 27T stock or 13-15T mod brushed motor and Tekin G-10 esc or Hara Twister.
I would also have to swap the new-style slipper for the original one when using the 2.65 topshaft, so would it still hold up to the above-mentioned motors?
Re: 2.25 Stealth or 2.65 RPM?
i would bet the stock slipper would be fine. only problem I've heard is that with the 2.65, you tend to wear out the top gear and idler due to being a smaller top gear with more agressive tooth profile(can't avoid it going to small gears). so longevity would be something to consider. if you have like 5 topshafts ready to use, sure, go for it.
otherwise, you should be able to gear the 2.25 I would think.
LTO_Dave
Post by LTO_Dave »
I actually grenaded a 2.65 a while ago, but I think it was faulty diff rings because other members had similar problems. :x That's why I'm hesitant to try another one.
I'm no gearing expert either, so any help with that would also be appreciated. :mrgreen:
Another benefit of me switching to the older slipper is gear choices because I have several that fit. But I'd have to buy new spurs for the new slipper setup because I only have the one included with the kit so far.
manual for the worlds car shows a 28 or 30 tooth pinion for 13.5 or 17.5 brushless motor, so I'd say start there. if sticking to a low wind brushed mod,say at 15t, I'd start at 18 tooth pinion and work down depending on wind.(lower turn, lower pinion)
harvey
Post by harvey »
I would stay with the 2.25 for parts avail, and if you are running a blinky 17.5, you can really gear them up. The 2.65 is in the wrong direction you'd want to gear a 17.5.
slotcarrod
Been thanked: 45 times
Post by slotcarrod »
Stock 2.25 is perfect. If you are racing use the vts slipper.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
+1 for the 2.25 but if you really want to go with an RPM for a 17.5T then go with a 1.96. :wink:
LTO_Dave
Post by LTO_Dave »
Looks like I'll stick with the trusty ol' 2.25. :D
I do have an RPM 1.96 conversion but it's reserved for a shelfer build. :wink:
RC10th
Been thanked: 1548 times
Post by RC10th »
+ another for the 2.25
