Rear toe
General info, Q&A.
tjf
Rear toe
Post by tjf »
Hi all
I need a bit of advice on the rear toe blocks etc please.
I have an RC10 team car and currently it has 3 deg rear toe on the inner hinge pin mounts. Now I actually race this car still and the 3 deg mounts are no longer made. In my instruction manual it says part no. 6360 mounts are standard for the car and 6366 rear hub carriers have 3 deg rear toe but on Towers site it list 6366 rear hubs as 1.5 deg.
Now if I replace the inner suspension mounts with the ones which are available how can I achieve 3 deg rear toe? Plus what would be the part number of the rear hubs I currently have that appear to be 0 deg?
Hope this make sense!!!
Thanks
Tim
Still building my RC10
Re: Rear toe
none of the inner arm mounts are available any more. the 6360 mounts would be 1.5 degree. the 6365 hub carriers (discontinued) are 0 degree. the 6366 hub carriers ARE 1.5.
Re: Rear toe
you could use the hub carriers from a 10t/gt, though. you can still get those in 0 and 3 degree i believe. you'll have to switch over to plain bearings.
tjf
Re: Rear toe
Post by tjf »
Thanks very much. Do you think these would be ok they are avalable on Tower http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=000446379&I=LX3387&P=K
Thanks
Tim
Re: Rear toe
those are for an rc10 gt. they're not gonna work, as far as i know. they shouldn't, anyway.
Re: Rear toe
these are pretty much your only option.
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=10945
PBR Allstar
Re: Rear toe
Post by PBR Allstar »
yeah, the GT ones don't work, I tried..... The fore and aft ofset is wrong. The GPM ones that scr8p listed are the only thing going to my knowledge. And they look to be 0 toe -3 caster
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Re: Rear toe
Post by Asso_man! »
yup, I confirm the GPM ones have 0 degree toe!!
Come and visit the stable
Users browsing this forum: No User AvatarBing [Bot] and 3 guests
