rear toe questions
rear toe questions
I have an earlier/1988 rc10 with the narrow rear track and it seems to have an excessive amount of rear toe in. How can this be changed/adjusted? I'd like to keep the car as close to stock as possible.
Re: rear toe questions
Pretty much every RC10 ever made has the same rear "track". The early cars came with the proper amount or rear toe. Post a couple of pics about your concerns and that would help allot. As far as modifying them to lessen the rear toe, associated made 0*, 1.5*, 3* rear toe options (inboard and outboard -per side). So with stock parts is is possible to have various degrees from 0* up to 6* per side. LMK if this helps, and post some pics -Jeff
- slotcarrod
- Been thanked: 45 times
3 degrees is what you want in the rear!
Rod Littau
- 577 Views
- 997 Views
Last post by Asso_man!
- 590 Views
- 1230 Views
Last post by peetbee
- 4966 Views
Last post by SRTracer121
- 614 Views
Last post by Group B
- 20 Replies
- 3171 Views
Last post by LurkingCAT
- 1929 Views
Last post by xxxmain
